I’m not sure how long. Its been an ongoing project for about six weeks doing bits and pieces here and there. I’ve just got to work out the springs and it will be done.
Thanks to you all for the kind words.
With 4 batteries installed the center of gravity is just behind the heat sink. With your thumb and first finger snug up against the heat sink the light is pretty effortless to carry. I will have to take a picture.
I had not thought about removing the ano from the head. I may have to do that. Does anyone know what the equivalent off greased lightning is in Australia? As far as measurements go its a field I have not ventured into. I have intentionally not given any distance measurements to stay away from any controversy.
Thanks mate. l’ll send it up on QLD rail. Everyone here is still in bed so I cant find the kitchen scales. Standing on the bathroom scales with and without the light the difference is 1.1kg which would be about 2.41 pound. If this is not close, when I find the kitchen scales I will amend this. I’m not sure how much I had built when you were here but it sorta just slowly evolved.
Hi Mr jacktheclipper I was tossing up whether to ask you if you could make me one of your famous lanyards for this light but in some sort of handle format. I could make an eyelet to go on the tailcap and put a noose over the head of the light. I’m not very creative so I dont know. What do you think?
I use the crystalline version of drain cleaner. The only parts that I have done are fairly small. I cover the bottom of a 24 oz drinking cup with about 1/4” of lye and fill the cup with COLD water. Stir to dissolve (be careful to not splash it on sensitive parts of your house or body). Cold water is important since it releases a lot of heat when it dissolves. Hot water can cause it to splatter.
I suspend the part to be treated in the cup using a couple of largeish zip ties. One is full length, the other is a piece cut off of one and slid into the head of the long one. They are arranged in an inverted T shape. Jiggle the part every few minutes. It takes around an hour to strip most parts.
Well now . That light just has to be fairly heavy , so a paracord handle would need to be fairly wide to be comfortable . It would be nice to know which battery configuration would be the most used if the lanyard was to be attached to the tailcap . If the lanyard /handle was made to noose over both ends , however , the light could be used in any configuration and the padded section of the lanyard would be at the point of balance ...
Let me think about it some more when I haven't hadseveral beers tomorrow .
A worthwhile testament and incredible work. I would say you have out done yourself but I think you have been over modest in the past. All the best to Peter.
The balance point is 50mm from the fins with four batteries. That is about half my hand width which will be why it's so easy to carry. I have added a picture in the first post.
I’ve just been handed the kitchen scales that were never calibrated 15 years ago and the official all up weight with four King Kongs is 1.25 kilograms which is 9.25 pounds.
Gee’s. Buggered that up. Your right. I suppose you get that trying to scoff breaky down and out the door to work. I never did trust calculators. it’s another conspiracy I bet. Sorry about that.
Excellent build! What a beast, and a perfectly balanced one at that.
I would probably ano the new parts for heat dissipation purposes, but it would look really amazing if it was all polished aluminum.
I’ve got camera lenses that weigh more than that, and then there’s the camera body, flash unit, flash brackets….Try holding that for 14hours on wedding day!
Steve, that work looks factory man! Excellent detail work and great pics! Love how your daughters fancy fingernail polish let’s her hold up “10 lbs” with one finger!
