I did buy some magnets a while back, but Iād feel safer with a dab of solder tbh, less chance of dropping the thing and having the magnet short the light - and these are expensive lights.
I think the reverse-polarity protection would also prevent shorting the light, assuming the magnet is small enough to fit. The positive contact has a small plastic bowl around it, which would make it nearly impossible for a flat object to contact both the poles at the same time.
The RRT01 looks nice, but I donāt need another light (I have to keep telling myself this >.<).
But what if your other lights stop working?
They canāt all stop working!
Course they can. Buy it - you know you want to.
FT finally carrying a Convoy EDC w/clip . The S4 is a decent looking 18650 lightā¦but what do you think about the way the clip mounts to the ring surrounding the switchā¦wonder if it will hold up? Seems like it might eventually cause stress fractures along that thin rail and shear off. Nevertheless Iām happy they are getting Convoys w/clips in.
FT listed a lot of new products for flashies :)
A Convoy S4 host and many Convoy S4 with XM-L with different binnings (T4-7C, T5-5C, T6-3C, T6-4C, or U2-1B) and 4/6/8 x 7135 (similar to the Roche F12 a few days ago). One with a XP-G R5-1A, too. Price range: $21-$26 Link, only the host $15,17 - save 5% with coupon BLF. You can use one link and choose any model with the drop-down menu - non aff-link
Also some Olight M20 filters (blue - red - green) and a diffusor. Each for $6,71, diffusor $5,02.
And the listed some XP-G2 LEDs on 14, 16 and 20mm base (XPGBWT XP-G2 R5-1A 472-Lumen 6500-7000K LED Emitter).
A little bit confusing is the information: Input Type DC 2.8-3.15V. Couldn't I use it with the Nanjg 105C?
FT listed price: $2,86-2,87 Link - non aff-link
Iām getting to the point where I donāt have to keep telling myself that. Most lights donāt look very interesting any more because very few have anything sufficiently new or different compared to what I already have.
The only types I donāt have yet (and might want) are a high-CRI light (L10?), a pencil-beam aspheric thrower (ZY-C10-S), and a custom or BLF-edition light. Oh, and a true strobe light, but I just have to re-flash one of my Convoy S3s for that.
Iāve mostly moved on to upgrading other parts of my EDC, like a nice rainbow titanium nitride Fisher Space Bullet pen with purple ink and a little notebook, a keychain diamond-coated file, tritium and regular GitD keyfobs, an S-biner-based keychain, a Leatherman Juice S2 compact multitool, a TPU case for my phone, a new purse, lip balms, etc.
However, I got a bunch of great little stuff from FastTech today, like USB cables and adapters and stuff. Iāve also gotten some nice steampunk necklaces there, a Valentineās gag gift (solar-powered cockroaches), a bike-themed knife for my friend, and other random stuff. And Iāll probably be getting some Android mini-PCs and a tablet soonish, of which they have a very nice selection.
Are all the Convoys reverse clicky? I generally like them, but the reverse click is a dealbreaker for me.
Sunwayman Mirage for under $80!!! I wanted this light since it was released and ordered it few weeks ago from Ebay. I got it for $105 what I thought then as a fair price. I just never expected FT to have them so cheap, considering the limited status and all. Had I only waited for a couple weeks moreā¦ :_(
Obviously I am the only person really liking this one!
I do need it then, because I donāt have one with the variable control ring. >.< I also want need a high-CRI light but in AAA package. The L10 was tempting, in pink especially, but the Preon has spoiled me.
To be fair, although the RRT01 is a very nice light, Iāve only had it for a day and Iām already reaching for my trusty ZL H51 half the time because itās inconvenient to use one hand just for holding a light. I also keep having to think about it to remember which way to turn it, since itās the opposite direction from traditional twisties. The RRT01 is the best Iāve found for sublumen modes though, given that over a third of its range is dedicated to 0.005 to 2 lumens.
Iād probably put the RRT01 in my top four recommendations for a small EDC though, after the ZL H51, ZL SC52, and pretty much any decent 1xAAA keychain light.
Thanks, Toykeeper. That really helps. Its the low lumen variability that interests me the most. I do wonder how it compares to having well spaced low modes, like on your Zebralight.
Well, the runtime on the RRT01 is a bit sad with a maximum of 4 days (compared to 3 months on the ZL SC52). So, itās not a great torch to leave on overnight. However, it can smoothly and easily adjust to any level. And by āany levelā, I mean it turns on with an output that is so dim I can barely see it if I hold it millimeters away from my eyeball in a pitch-black room with well-adjusted night visionā¦ and then it goes up smoothly from there, though the granularity gets less fine near the high end. A fair amount of its range is dimmer than a tritium vial.
On mine, the control ring seems to rotate about 150 degrees. From 0 to ~40 degrees, itās off. From ~40 to ~100 degrees, it ramps from 0.005 to 2.7 lumens. From ~100 to 150, it ramps from 2.7 to 500. (Iām using 2.7 because thatās the point where it looks about the same as the SC52 on its 2.7-lumen L1 mode) So, thatās about 50 or 60 degrees worth of low modes, and another 50 for medium, high, and turbo. Itās a pity that almost a third of its range is just āoffā though.
My main gripes about the SC52 are that it lacks a mode between 0.34 and 2.7 lumens (0.9 would be nice), and that itās a major pain to switch between sub-lumen modes (requires 16 clicks to go from 0.01lm to 0.06, or 18 clicks to go from 0.06 to 0.34). So I generally just leave it configured for 0.06lm (dim night light level), and reach for my H51 at 0.18lm when I want a brighter mode.
The RRT01 does away with all that nonsense and lets you set it to whatever level you like in a fraction of a second.
I have one on the way. Not that enamoured with the colour, tbh, but I wanted the AA extender, and for a few dollars more, probably worth it. Like you I was amazed Fast tech has it at all, never mind at such a good price.
They do sell a AA extender on itās own - http://www.fasttech.com/products/0/10004131/1306300-sunwayman-ap-05-aa-extender-for-m10r-m11r-v10r-
Yeah, I saw that, thanks. I just figured that I might as well spend an extra few dollars for the ālimited editionā version - if I donāt like it I should be able to sell it easily enough.
It looks like they carry copper for xml now.
20mm
https://www.fasttech.com/products/1/10004183/1315314-cree-xm-l-20mm-brass-star-base-plate
16mm
https://www.fasttech.com/products/1/10004183/1315313-cree-xm-l-16mm-brass-base-plate
