I've done a top-up/discharge/charge/discharge on a few of them so far (before I got distracted by the Fujitsu packs) and the numbers don't look too hot. But this whole hobby charger thing is completely new to me, so I need to play some more before I know how the numbers I get relate to reality.
Sorry about the “distraction” :)… but it was a good one, right, I hope :)?
So what kind of numbers did you get, so we can compare?
I’m doing a charge on one of them now, and then I’ll do a discharge to 3.0V (since I got help here… I turned the safety time off, and will be watching it “like a hawk”, esp. after this afternoon’s “adventure” (sparks, smoke, and burning odor).
Will post back…
Jim
I grabbed 5 at random to test but only finished 3 of them, but they did 1321, 1338, & 1340. 1A down to 3.0V. But, I haven't done discharge tests on any other brand/capacity cells to know how the numbers from the Turnigy relate to the advertised capacity.
Did you see the pic I posted in the other thread about the 'distractions'?
Hi,
No, sorry. Which thread was that? I’ve been going blonky with all of this charging/discharging stuff :).
BTW, do we know what these from the pack are suppose to be rated at (too lazy to check)?
Jim
Hi,
Re. distractions, was it post #94 on this thread (FYI - some 'new' Fujitsu laptop batteries)?
If so, that’s a good kind of distractions, right?
Also, I thought another person on the other thread just threw the Fuj/Pana batteries into their i4 charger (so less than 3 weeks)?
Jim
The first cell from the Fujitsu packs took 2901mAh on the first charge, haven't done a discharge test yet.
12 cells, 3 series sets of 4 cells in parallel, 9600mAh rating divided by 4 = 2400mAh.
The first cell from the Fujitsu packs took 2901mAh on the first charge, haven’t done a discharge test yet.
Thanks. Our posts crossed, but I think I found the post/pic you were referring to, showing 2901 mAh :)…
Jim
P.S. Now you know what I’ve been going through the last couple of nights :)!
I haven't tried doing more than one at a time on the hobby charger yet.
I haven’t tried doing more than one at a time on the hobby charger yet.
I haven’t dared do that yet, too, so post back, either in this thread, or, maybe another thread, if you do that? Can you also include details of your setup, etc. if you do do that?
Going off of your sig, this is a learning experience…
Thanks,
Jim
comfy,
My charger, discharging @ 1 amp, is already at 1202 mAmps @ 3.42V, so it’s got a ways to go yet, so the capacity seems to be > 1200 mA.
I did a full charge before starting the discharge, and I have the safety timer is OFF.
Jim
comfy,
Here’re the final numbers for the one randomly selected (but good wrapper) battery from the pack. Again, my Accucell is set with safety time to “OFF”, for these, and both charge rate and discharge rate were set to 1.0 amps:
1st Charge: Time: 71:58, Ending Voltage: 4.20V (confirmed with separate DMM also), 597 mA
Discharge: Time: 147:39, Ending Voltage: 3.00V, 2257 mA
So, it looks like the capacity (down to 3.00V) for this battery is 2257 mA.
This’ll probably be the last one I do tonight…
Jim
OK, I’m a little confused. Are these the BAK cells that are showing 2200mah?
Marc.
Yes - though I haven't seen the docs that link 'BAK' to these blue cells marked with CJ. I couldn't find anything useful on google, though that's not unusual these days, what with their not-at-all helpful policy of replacing your search terms with what they think you meant instead.
Yes - though I haven’t seen the docs that link ‘BAK’ to these blue cells marked with CJ. I couldn’t find anything useful on google, though that’s not unusual these days, what with their not-at-all helpful policy of replacing your search terms with what they think you meant instead.
Haha, yeah that’s Google.
So these look good then. Like I said I was going to buy one for my laptop so presuming they are all made by one manufacturer and use the same cells, I should by happy.
http://www.ebay.co.uk/itm/190776517081?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1423.l2649
That’s one I was looking at. Do you think it’s the same?
Marc.
Looks identical.
Looks identical.
That’s what I thought. But I’ll probably get Ultrafire cells in mine :_(
Going to buy one.
Thanks Comfy,
Marc.
Crude but interesting results...
Solarforce S1100, 3x18650 in series, w/low batt warning that trips at 3.3v/cell. Tailcap draw is 1.22A, current delivered to the emitter is 3.3A.
All cells fresh off the charger, start voltage of 4.21V.
Samsung INR18650 15Q, runtime on HIGH: 1h08m
BAK/CJ 6K00112, runtime on HIGH: 1h30m
Update:
With 3 Panasonic 2900mAh cells the same test gives 2h08m runtime. So if you plot that out, these blue CJ cells fall right in the middle between the 1500 and 2900, so that looks like capacity around 2200mAh.
I just wanted to bump this.
I bought this pack on ebay: New Acer Pack
Notice it shows “Cell made in Japan”
The pack I received looks identical, however, there was permanent marker over the word Japan, and the word Acer.
Cells are blue and look just like the ones in this thread, numbers are slightly different though. They are marked “CJ”.
Very unhappy, was expecting Sanyo cells, not counterfeit.
They're decent cells, I haven't had any of them misbehave. They still get used regularly even though I now have a ton of nicer pulls.
They’re decent cells, I haven’t had any of them misbehave. They still get used regularly even though I now have a ton of nicer pulls.
Yeah I expect so, but I bought this pack expecting Japanese cells, not decent Chinese cells. The fact that the pack has “Cell made in Japan” is a kicker.
I am going to test the ones I got, but I already opened a case on Ebay. No one needs counterfeit batteries on Ebay……the ones that are obvious “replacement” battery packs are fine, but when they are marked “Japan”, and “for Acer”, it is pretty bogus.
