Sorry about the “distraction” :)… but it was a good one, right, I hope :)?
So what kind of numbers did you get, so we can compare?
I’m doing a charge on one of them now, and then I’ll do a discharge to 3.0V (since I got help here… I turned the safety time off, and will be watching it “like a hawk”, esp. after this afternoon’s “adventure” (sparks, smoke, and burning odor).
I grabbed 5 at random to test but only finished 3 of them, but they did 1321, 1338, & 1340. 1A down to 3.0V. But, I haven't done discharge tests on any other brand/capacity cells to know how the numbers from the Turnigy relate to the advertised capacity.
Did you see the pic I posted in the other thread about the 'distractions'?
I haven’t dared do that yet, too, so post back, either in this thread, or, maybe another thread, if you do that? Can you also include details of your setup, etc. if you do do that?
Going off of your sig, this is a learning experience…
Here’re the final numbers for the one randomly selected (but good wrapper) battery from the pack. Again, my Accucell is set with safety time to “OFF”, for these, and both charge rate and discharge rate were set to 1.0 amps:
1st Charge: Time: 71:58, Ending Voltage: 4.20V (confirmed with separate DMM also), 597 mA
Discharge: Time: 147:39, Ending Voltage: 3.00V, 2257 mA
So, it looks like the capacity (down to 3.00V) for this battery is 2257 mA.
Yes - though I haven't seen the docs that link 'BAK' to these blue cells marked with CJ. I couldn't find anything useful on google, though that's not unusual these days, what with their not-at-all helpful policy of replacing your search terms with what they think you meant instead.
So these look good then. Like I said I was going to buy one for my laptop so presuming they are all made by one manufacturer and use the same cells, I should by happy.
With 3 Panasonic 2900mAh cells the same test gives 2h08m runtime. So if you plot that out, these blue CJ cells fall right in the middle between the 1500 and 2900, so that looks like capacity around 2200mAh.
Yeah I expect so, but I bought this pack expecting Japanese cells, not decent Chinese cells. The fact that the pack has “Cell made in Japan” is a kicker.
I am going to test the ones I got, but I already opened a case on Ebay. No one needs counterfeit batteries on Ebay……the ones that are obvious “replacement” battery packs are fine, but when they are marked “Japan”, and “for Acer”, it is pretty bogus.
got a new dell replacement pack with these.
all around 2190mah and 50mohms
tested with a triton and a dick smith esr kit.
i won the pack for $0.99 free shipping so i figured what the hell?
it did not fit the laptop i thought it would and with seconds counting down no time to double check.
so if new they are decent budget cells.
the 50 milliohm i r is why they did well in the above tailcap tests.
