I’d just like to back up ramblings here, this light is awesome, I am hellish impressed with mine, infact I’m waiting on it going dark so I can go out for another play test session.
Its also a really easy build, I would though suggest people go with the ld-29 driver from fasttech and xp-g2 if they want to keep things a little more sane, on this build, that would mean three simple solder connections in total and stupid amounts of throw J)
The model of the XinTD C8 was noted briefly but I'll restate it here, it's the U3 bin with the 1C tint.
I got it from intl-outdoor here. It's the 3-mode non flashy one but that doesn't really matter.
the xin td c8 is very impressive throw considering the reflector diameter…it’s not left too far by L2.…
I guess maybe my X9 can be out throw by the xintd u3
Dunno if I mistyped this earlier, but just shining over peoples houses, etc. to tall trees above, the spot of the L2 has almost double the distance capability. The XinTD isn't really visible >250m, but the L2's can be seen illuminating trees >400m away. I just can't post such long range pics due to equipment unavailability.
According the to the product pictures on FT the sixth picture shows screws included. Wanna double check?
I have no experience with the host only, so I'm pretty useless here.
I can only guess that since they are made in China somewhere and not 'Merica, they'd be metric and from there it's only a rough estimation of what pitch.
I'd be the first to bet M2 because of the diameter.
Best solution would be to pop down to your local hardware store with the torch and lightly try to screw it in.
I, too, would like to know. All the usual sources are all out of all versions and I feel like having as dedomed version though I'm not sure I want to sacrifice mine.
