Assembled length = 9cm
Body is a simple 7cm ano tube closed at the tail.
6 front threads, an O-ring groove, no tailcap.
Some knurls, steps, and a clip groove and clip.
Very light.
4 coil 1cm high spring is jammed into the base.
The head is 2.5cm long, 2 threads screw on SS bezel, O-ring, TIR.
The pill and driver are behind a partition with the LED poking through a hole.
Are you saying that the O-ring is in one position (green?) and to move it to a different position (blue?)? It’s hard to see the lines on the interior of your drawing.
Edit: Or did you mean to move it from the blue position to the green position? FYI, I don’t have the lights yet, so can’t visualize it :).
Actually, so this brings up a question: The original place where the O-ring was had a groove, like it was meant to have an O-ring there. Since we’re removing the O-ring from the TIR lens, is the water-proofing still intact? Seems like water could enter from the front of the lens?
I’m a little confused. Are we using BOTH white o-rings. The one wrongly installed at the factory AND the one that came loose in the box? The first one going behind the lens instead of in the groove in front of the lens. And the second one going on the threads connecting the upper body to the bezel as shown in Ohaya’s picture?
I think it’s not both, but rather move the one that is on/around the TIR lens to the threaded area, but then, there’s the question I posted about what waterproofs the lens/bezel area.
Apparently when the O-ring was around the TIR lens, it was causing some rings on the beamshots.
