I really like this drop-in
19 posts / 0 new
trooplewis
trooplewis's picture
Last seen: 2 years 1 month ago
It just makes more sense to me in terms of runtime, I just ordered 2 more.
-XP-G, R5 320 Lumens.  Yeah, maybe.....
-Tight hotspot with the smooth reflector, pretty throwy.
-Runs on .8 to 4.2A
-Pulls less than 1A on high with a CR123
-$13 from Solarforce-Sales
-3 modes, no ^%$# blinkies
-IT'S LABELED with voltage, modes, etc
http://solarforce-sales.com/product_detail.php?t=RB&s=10&id=113
Rats, finally sold my 2010 509hp Mustang...now I can buy more lights!
Sold the red one too! Now guess what I drive, doing my penance for 500 hp commuters...
http://dreammustang.com/
http://i884.photobucket.com/albums/ac47/Ha
Edited by: trooplewis on 05/14/2011 - 19:12
old4570
Last seen: 2 weeks 16 hours ago
If I didnt have so many XP-G R5 drop ins already ...  I would buy one ...
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
soytnly
Last seen: 2 years 11 months ago
Yep, we do think alike, that's about my favorite drop in.  I have one more on the way...I think it offers a great combination of brightness, throw/spill, efficiency.  I'm sure I'll end up with more...I've been tempted by the manafont R5 for a few bucks less, but the 5 mode format kills it for me.
Dave
trooplewis
Yes, it is almost emotionally relieving to not have to think about "powering through" the 2 useless and sometimes embarassing blinky modes when you want to get from Medium back to High.
trooplewis
I'm using it in my CR123 powered mini-P60, so that was measured with a 3v and also a 3.7v rechargeable.
Be-Seen, I just checked it with an 18650 and it pulls 1.4A with that battery (Hi-Max 2600)
handy
Last seen: 5 years 8 months ago
I like it in my L2R body, great throw for R5, also check out those new OP reflector for XP-G drop-in available, they give nice smooth beam pattern in OP setting.
The SMO reflector has a tight hotspot but also slightly doughnut effect there, hotspot edge seems brighter than the center.
It's my favourite drop-in for my daily duty, mostly the OP I used Big Smile
hansheng
Last seen: 7 years 1 month ago
i just brought one too Big Smile
HID45
HID45's picture
Last seen: 5 years 2 months ago
I have one coming, glad to hear its good item. Gonna gift it along with L2r. After I discovered the world of Atmel re-programming, theres no coming back for me to ready-made dropins. I just love the lower than moonlight of 4sevens low too much...
Dsoto87
Last seen: 7 years 5 months ago
Ive had one of these but dont know where I went wrong. It only works on lithium ions. On 2 alkaline AAs its dim even on the highest setting. Low is like a moonlight mode. On 2 NiMhs its even lower. There is practically no low mode. You can barely tell the emitter is even being powered.
Anyone know what might be the problem? I never loaded more than 4.2 volts into it (ie: two CR123s) so I have no clue why its doing this.
Langcjl
Langcjl's picture
Two cr123s would be 6V
Piers said " ....but who wants enough light, when you have the option for far too much "
E1320
E1320's picture
Last seen: 1 year 9 months ago
So I had this 5 mode XM-L drop in that I got from DX in a 504B that I was not using because of the stupid flashy modes plus it only pulls 1.4 amps on high. It had a NANJG 101-AK driver and I found a post showing how to convert it to 3 mode with no flashy BS. So I did the conversion and put it in one of my 501A mini P60 hosts. Results decent high not quite as bright as the Manafont drop in but I got a much lower low and a decent medium not to mention a huge improvement in run time.
http://www.dealextreme.com/p/cree-xml-t6-5-mode-6700k-450-lumen-smooth-a...
If you look at the picture on the chip on the bottom right you add a blob of solder to the bottom two right legs and you eliminate the flashy modes and get a nicely spaced three mode driver that is perfect for the 501A.
I am already visualizing the duct tape over your mouth.
Match
Match's picture
Last seen: 3 years 2 months ago
Agreed.  For a ready made drop-in, that solarforce 3 mode xpg is one of my favorites.
Dsoto87
yes i know. i was giving an example of skmething i did not do
Piers
Last seen: 1 month 4 weeks ago
As Langcjl pointed out 2 x CR123's would be 6v, if the driver really isn't rated that high then you've probably killed it.
So when you try to run it on 2 x AA it's probably trying to run it direct drive, 2.4v isn't enough.
Dsoto87
Ok I guess I worded it wrong. Let me try again
I did NOT run it higher than 4.2v (ONLY RAN WITH 1 18650, 2 AA alkalines, 2 NIMHS). I than gave an exmpale of somethign I DID NOT do which was put 2 CR123s.
To put it simply, I never ran it higher than the reccomended voltage range so I dont know why it wont run off 2 alkalines or 2 NiMhs
Dsoto87
trooplewis
Have you taken it apart and checked the wiring?
If it has always done that, contact Solarforce and have them replace it.
atbglenn
atbglenn's picture
Last seen: 9 hours 48 min ago
I got the op version for my L2m. Running a single 880ma 16340 I get about 25 minutes on high before it turns off for a moment. I got some 1200ma 18350's on order. They should fit, right?
gcbryan
Last seen: 3 days 10 hours ago
Haha...Dsoto87 I understood what you were saying from the beginning but it is funny (and interesting) to see how different people interpret the same thing Smile
