Initial thoughts:
*Very lightweight and small for an 18650 light
*Feels good in the hand. Nice size and quite grippy.
*Very nice beam pattern with good tint.
*The clip was VERY hard to remove. That sucker didn’t want to come off at all. I had to pry it off with a screwdriver. This caused a few scratches to the anodizing around the top edge of teh clip slot. Even though this isn’t a screwed on clip, if you use it for pocket carry I think there is very little chance the clip would come off accidentally.
*Upon receiving the light, the bezel o-ring needed to be reinstalled as it was in the wrong position. This was expected based on the earlier notice from Ric.
*The head turned extremely easily when I received the light. Close inspection revealed that there was only 1 o-ring between the head and the body even though there was a second slot. I grabbed one of the spare black o-rings from the box and stuck it in this slot to give much better tension between head and body.
*It is hard to reliably change modes without 2 hands. One-handed operation seems to often result in jumped modes.
*I haven’t tested it yet, but I doubt this light will work with flat top cells.
I managed to remove the battery, but it was tough. I soldered a strip of tin to the end of the cell as a handle, then used pliers to grip the handle and remove the cell. It took some effort, but it worked.
After seeing so many that got good units I am a little irritated as if the first 100 were just rushed out the door. As stated earlier I have all kinds of little quircks with mine that many folks do not. I did replace the O-Ring as the diagram shows and it did fix the rings. The issue there with mine was as soon as I took my metal ring off the debris from the optics where if was forced together and ultimately crashed, fell into the optics. pretty irritating. I hope everyone else gets a good one. For now I will reserve further judgement till I get a reply back.
I may do one better and put together a video review to post on it as soon as I get time.
Slapped a quick video together anyway. As you can see in the video the Sanyo UR18650ZT do fit till they get 3/4 of the way down the tube where the machining is not complete. Also I show tapping the light to switch modes, it looks like I am hitting it hard somewhat but I am not. The noise you hear is the battery rattling around in the tube. Also if you look at the end of the video you can also see the white crush ring on the optics where it was crushed during final assembly I imagine. I did not take time to show the other issues or the debris in the optics from loosening the optics to install the O-Ring correctly. Like I said, I believe I may have gotten the lemon. i did post this on another forum but figured I might as well add it here as well.
Don’t have one in hand yet, but to fix the bump-for-mode-change problem, could you reach down there with some hemostats or long needle nose pliers and stretch the spring a little? I imagine the mode change is coming from the battery bouncing just enough to break contact.
I’m glad I held of on buying one of these. Best to give it a few months so they can work out the kinks and produce a light that has gone through sufficient quality control.
I was able to pull the spring and stretch it a bit but it is pretty weak and it really didn’t do it much good. I also sanded the tube down to allow the Sanyo to slide in. The light will not allow any of the protected cells 69 +mm in length as well. They are too long. That leaves out the Panasonic and Sanyo 2800+mah protected batteries it was originally said to be compatible with.
I figured out where that slot for the 2nd O-ring is. Pic below. The head feels much more secure after adding the 2nd O-ring, and it doesn’t turn on everytime you touch it now.
Also, BTW, the small, black O-ring is the one that goes on both the 1st and 2nd slots, not the larger white O-ring. FYI, one of my lights had NEITHER the 1st or 2nd O-ring:
I took the picture with the Ti one, because you can’t really see the O-rings on the black one.
Edit: The threads and the O-rings are as dry as dust - I’ll be putting some grease on now…
I don’t know, but they may have eliminated the list because they’re done shipping the pre-orders. Maybe if you see RIC online, you can PM him, or email him via their website?
Weird there’s so much quality variances….My Keeppower 18650 3400mAH batteries fit in my black DQG 18650 w/ XM-L2 without a problem. The head on mine is nice and tight even with only one o-ring.
Well I’ve had this light for two days now and am still amazed that it’s the same size as my larger single CR123 lights e.g. HDS Clicky, SF E1L…
My tracking does work on Singpost. Says it shipped to the UK on the 30th April and arrived on the 3rd of May - hooray. Sadly 7 days later from touching down in the UK and no sign of it
Mine arrived today in Amsterdam, hooray! . And I am delighted, it is just as nice as I came to expect, I think it looks extremely cool. I am lucky to have gotten one that isn't faulty. The finish is a nice matt black, it came with the white o-ring in the wrong position, with the two black ones in place, one spare white o-ring and two spare black ones. Threading was dry, cleaned it a bit and lubed it with a little silicone grease, one-handed operation works fine. The neutral led is quite cool, rough guess 5500K. I think this will be a good bike-light too.
