When you solder the braid to the traces, how do you get the solder to now flow into the whole braid?
When I working that Tiablo and tried something like this, in just a sec of contact with my soldering iron, about .5 - 1 inch of the braid would get impregnated with solder, so I just had one stiff piece of soldered braid. When I tried to bend that, it pulled the traces off of the edge in several places :(….
Or, if you have too much free time, or need to fit a ~20mm driver in a p60, you can do this:
So would the heat transfer be better, since it has a much better connection to the pill, or worse, since it has less contact with the light body (it's a loose fit, and only sits on the little shelf)? It's definitely less convenient as you'd have to do this for each dropin while the split ring spacer stays in the light.
/end thread hijack
On my first dropin, when I couldn't get the solder to stick I put down the iron and grabbed the butane torch... and melted off all the components on the backside of the driver. :Sp
I lightly tin the small area where the braid is to adhere to, then wipe off any excess solder from the tip of the iron, and press it down on the braid until it sticks to the tinned area.
Actually, you don’t even need to solder it to the top side of the board. You can fold a piece of braid and hang it accross the edge of the pill, press the driver in tight, and trim and fold the braid from the outside of the pill, back over to the trace on the driver. Then flux and solder. It accomplishes the exact same thing.
The trick for doing the stars is this: Put a blob on the star, big enough that the surface tension makes it, well, blobby... do the same on the ground ring. Let it cool, then with just the very tippy tip of the iron, lightly touch the top of the blob on the star, pull the iron across to the blob on the ground ring, and then pull the iron away. Do it in one smooth continuous motion - if you completely melt either blob, it won't work.
I think he wanted to know how to attach the braid to the top of the board without the whole length sucking up the solder. But after that, I agree…flux,flux,flux. Before I push the driver into the pill, I flux the braid, even though it comes pre-impregnated.
The last batch of 'Goot Wick' I got claims to be fluxed, but... I guarantee you, it is not. Which is fine, really, as it can be used for stuff where flux would have to be washed out (braiding springs etc.), and flux can be added when it is needed. And by adding flux you can control where/how much is impregnated with solder.
I find the solder-only method of bridging the stars easier, as compared to trying to keep a small piece of wire in place. I always end up with the wire stuck to the tip of the iron (d'oh!). Might go smoother if I used a long piece of wire that's easily held in place and then trimming off the excess at the edge of the pill, but I have the blob-to-blob method down pat.
You can still bend the braid over without lifting any traces if it sucks up too much solder, just hold it flat to the board with needlenose pliers, then bend it over the corner.
