love it, next is a brushless ducted fan for real horse power J)
Wow! Nice job!
that’s scary - I’m already worried about popping mattresses as it is! Found another use for it already - annoying the lab technician at work
thanks!
great mod !
I hate that 6V lead acid batteries… laptop pulls rocks !
Nice up-cycling job there !
thanks! The wife was happy to find more space in the fridge salad draw too I just remembered, the SLA battery had “1.25A initial current” written on it, so I must be pumping many times that through the motor - no wonder it spins so fast J) I might need to add some heatsinks to the switch now though…
Its crazy how small that motor is inside there
Nice work.
Nah, that motors huge, look up some of the small brushless rc motors, I had one smaller in diamter than a 1 pound coin, it spun a 3” prop at 46000 rpm and impressively destroyed my thumb when “interfered” with
well, it survived this weekend’s camping trip just fine, inflating and deflating 3 queen size mattresses (including one double thick one), plus topping up one of them periodically. It was pretty fun using it to help get a camp fire going too.
Unfortunately the 2 parallel banks aren’t well matched, as one pulls down much further than the other, so I may have to swap some cells around (mix the two banks) or rebuild it with some other cells. Then again, for how much it’ll get used, it’ll probably be fine just as it is. I just can’t get my head around how much current the motor must be drawing to pull the voltage on a 2S4P ~8Ah pack from 8V resting to 6V under load! When I recharged it, just over 2100mAh went in. Crazy stuff.
Best mod I’ve read all year not flashlight related. Supercharged air mattress inflator. We all should have one. How many times have we pumped up air beds or the like by hand pump or even the 12 volt car blowers and cursed every minute as the air seemed to escape quicker than it goes in. l’ll take one.
thanks MRsDNF! You can even use it for fire priming in glass blowing, according to my cousin-in-law Postage would probably be prohibitive, but if you have one I’ll mod it for you
Theres another thought. Flame thrower. This gets better. I think its time for TexasPyro to step in. I’ll have to study up on the likes off multi batteries in series and parallel configuration as I dont understand it at all. Cheers.
hmm, that’s stepping a little too far from the world of crazy into the world of missing fingers
the series vs. parallel battery thing is pretty straightforward. You have as many batteries in series as you need for your source (6V motor in this case), then you add enough batteries in parallel to share the load. So if you have a tiny load, say 1A, then 2 cells in series (2S1P) is plenty. If you have a 10A load (which I have a feeling this is, if not more), that would demolish that battery and you’d get no usable runtime at all as it would pull the voltage down to 3V per cell in an instant. So then you add more cells in parallel until the current draw per cell is within the range it can cope with. So, in my case 4 cells in parallel isn’t enough share the load and the cell voltage sags badly, although one bank is far weaker than the other.
If I were to do it properly and actually spend money on something (gasp!), I’d use some high drain (20C+) li-po cells instead. Capacity might be a smidge lower than new li-ions, but usable capacity would be far higher and I’d need fewer cells.
Thanks Mr muppet. I’ve just printed the explanation out as I will have to read it a 100 times for it to start making sense. I could keep masking questions but just not now.
I just found this old post but I think this is really nice work. I dont think you can make a mattress inflater supercharger like this
THX! Great mod.
Yeap! Great mod. :nerd_face:
I read this post some time ago. We don’t car camp too often, and as such our air mattress just sits for the most part. But we have a trip coming up in a couple weeks, so I decide to fool around with the air mattress pump. filling the air mattress with the shop vac takes about 27 seconds, but I’m not bringing that camping. First, I did a little test. 4 1.5V D cell batteries power my Coleman 4D pump. When the pump is on, best I can tell I get about 1.5V to the motor, and about 3A. It would work that way, but what’s the fun in that?
So I took a power tool cell I got charged to 4.0V, and put it in my single cell charger. Used some aluminum foil to create tabs, and connected the battery directly to the motor through short clip leads. The battery drops to about 3.3V, and delivers about 5A to the motor. Much faster. I’m sure I can make this even better, but I’ll likely just use it like this for the near term.
Can’t imagine putting two cells in series. I will likely try one of my new 30Q cells at some point to see how they do, as it seems like I could do better than a 0.7V drop in the cell. May be my setup also, who knows. Fun stuff though!
Yeah, aluminium foil isn’t exactly the best way to connect them.
I would agree, but I did fold up about 4^2” of foil into little tabs, so there was a decent amount of surface area. The easiest would be to just dedicate the single cell charger to the pump and solder wires to the contacts with some nice tabs. But since it might be another 5 years until we camp like this again, I probably won’t.
I’ll add my 30Q charged to 3.8V also dropped, but only to 3.3V also. It was definitely delivering more current based on the sound, but at the levels being delivered (+5A) my meter with really long leads is not going to do the measurement justice.
