I’m happy with the fact that the copper really puts the heat out to the body now. When I fired this thing up to do beam shots, the body was warm in less than 30 seconds and after a minute there was no mistaking that this thing was pumping the heat out. Output is better than stock, but it’s also a cool white versus a warm white, so much of that is just the fact that cool white always “looks brighter”. Overall it was a success, but if I had to choose, I would choose the TR-A9. It has a more defined beam and is a better thrower. It’s slightly heavier and I like that. It also does not feel like it’s going to fall out of your hand, like the EA4 does. The EA4 is slick and harder to hold onto.
The A9 has issues in stock form. It is touted as 2s/2P, but I found that it was manually changed to 4S by someone along the way. The light I got was 4S in configuration and that's not at all necessary unless they had the wrong drivers for 2S and had to change the lights. It has a cheap glass lens and that's the biggest downfall for me, along with the poor output in stock form.
My vote goes for the A9 in modded form and the EA4 in stock form.
An MT-G2 with 14500s in the ea4 body would have been cool given the improved the heatsinking. Despite what appears (from your ea8 teardown) to be a small contact between the heatsink pad and the walls of the body, my stock ea4w seems to gets warm almost immediately. In a low power device like the XM-L led is there more heat generated than the flux between the 2mm disc and the body can handle? If not they’d probably get quite a bit of mileage simply by improving the interface between the parts.
Is that the same micro switch you referenced before? Nice build. I learn with each build but it’s still hard to acquire more skill doing infrequent work. You do an excellent job pushing your skills to keep up with your enginuity.
This is my favorite shot. Apparently your new mod is so powerful that it vaporized your garbage dumpster! Better be careful with your garage door too. :bigsmile:
