[07-JUN-2013] Please testdrive BLF on a different server
On pic heavy threads is usually where it seems to be the slowest for me. On the new server the entire thread and pics load incredible faster. I couldn’t tell you what’s making the difference but they are a huge difference for me. Tried it again just now as the torture test is being run and its about like normal BLF.
Shall I give this a shot. :P
wget -H -r —level=1 -k http://198.199.90.139
Do it!
Threads: 11 Questions: 1578869 Slow queries: 31 Opens: 437 Flush tables: 2 Open tables: 400 Queries per second avg: 328.110
MariaDB v10 seems pretty nice. Drop-in compatible with mySQL, performance improvements, and free of the shackles of Oracle.
Ok, it is now running. :)
Threads: 6 Questions: 1668546 Slow queries: 31 Opens: 440 Flush tables: 2 Open tables: 400 Queries per second avg: 337.557
Wonder why the threads went down?
I opened 33 pages, just refreshing them every few seconds now.
I’m not actually checking the speed of the site though, is it holding up well?
EDIT: scaru, i’m using the easy auto refresh add on, it’s quite good!
Honestly, probably because I backed off. Want me to hammer it again?
Yes...
It’s pretty slow now for me, just click on one link at a time. It’s because the Apache workers are all busy and a long waiting queue. I’m keeping those values fairly low to save RAM.
Check it now. I just turned up the heat a bit.
Sure! I’m interested to see if the OS will step in or if it will let the DB run it into the ground.
Okay I lowered it to refresh 5 pages every 3 seconds. However it still has about 25 pages to load up first from before.
From where I am in the house I get about 3-6mbps down speeds, so I may not be affecting it much.
Looks like it just came to a grinding screeching halt :) I wasn't nice to it. :)
Threads: 10 Questions: 1778924 Slow queries: 38 Opens: 472 Flush tables: 2 Open tables: 400 Queries per second avg: 335.962
QPS is down slightly. So looks like the theoretical limit for this config is somewhere around 340 QPS? Not earth-shattering, but neither is the resource configuration.
Yep, Getting "Connection Refused" up the wazoo.. I'm going to leave it hammering away for a few more minutes to see if it fully crashes or if it recovers.
Yeah, completely down for me.
K. I just stopped completely.
Yep, doesn’t appear to load up now.
