Great host choice!
Are these cans strong like ‘in the old days’?
After can deposit was introduced, cans disappeared here almost completely. They came back a few years ago, but in more long-ish form with really thin walls. Can’t build anything out of that.
Good luck with your build!
Thanks!
Ehm… the walls are very thin and flimsy…
Im feeling quite sure its the same walls as the ones you have in Germany. The box is made somewhere in EU. It does not take much force to crush it with a hand…
When I measured the top diameter and saw how nicely a 50mm triple reflector should fit, it was just meant to be. Despite the thin walls. I will have to make it fairly “crush proof”.
Our friend runs a Mexican Food Restaurant and has large bottles of Mexican Coke, we always drink that when there, and go there all too often. My wife drinks Coke or water. No coffee, no tea, almost nothing else at all. So we go through a couple or 3 cases a month pretty easily.
Can’t wait to see how you pull this one off!
Edit: I have a very old Coke can made of tin, with the pull tab still intact. No aluminum save for the top with the old style tab that’ll cut ya.
Thanks RaceR86 for the idea. Instead of Coke cans I decided on VB cans. Unfortunately I may have to stop using this idea as my head hurts to much in the morning. Looking forward to whatever you create and dont forget to add Scotch. Tastes better than Mexican Coke then.
A Coke can is a great idea. This was my first impression as I see the Skyray King the first time. A can with three LEDs.
I prefer Coke instead of Pepsi. Maybe I would chose a special edition Coke can if it is available in Norway at the moment. A special flashlight in a special host.
I made a bike light from a metal shampoo bottle once, way back in the halogen days. I used it every week for 6 or 7 years and it’s still around somewhere. Can’t remember the name of the brand, had some guy with long hair frowning on it.
Looking forward to the build report!
ps. I only drink coke with rum, tastes much better
There is your Idea. You should join in on the fun Werner! So, when do we see the fishermans friend bonbon metal box light build?
Actually, I was thinking about using a sardine box (flat square box). But I have done a “”box”:https://budgetlightforum.com/t/-/17964” light, and that one will probably not be my last.
For this project, I wanted more space in order to make a bright NiMH light…
Im a bit surprised no one of the other builders have started a beer light build…
i was actually considering a aluminum budwieser bottle build... but thought it was too close to what you were doing. i was also considering cannibalizing my floor lamp for a build. the upright tube looks about the right size to fit a 26650 and it has a HUGE head on it (metal shade) lol
I don't know anything about drilling holes in glass, but I think I have seen oil used to help keep from shattering the glass. I can't swear to that, but here's a Wiki how to on it.
They use whatever is available locally. Corn syrup made from maize in the US, sugar made from sugar cane in Mexico and sugar made from sugar beet in the EU. Dont know about Canada (maple syrup? :D), Russia or Asia (Stevia maybe).
Moi, putting a crappy driver in a light? Im insulted…
I have the following options available. 2 different 5A drivers from lck-led, Qlite with extra 7135s, the original SRK driver, Dr Jones Lumodrv with a bunch of extra 7135s as options… Probably a few more inferior drivers…
Compared to all the above, Im thinking on some more sophisticated stuff :face_with_monocle:
…maybe… Otherwise, I will pick one of the above…
Thanks!
Epoxy would probably work. I plan on use some metal instead… Should be better for heatsinking…
Thanks…
Helpful, but my attempt was too optimistic. Not a surprise.
I considered to try drilling from both sides (like recommended in the link), because the glass got the crack when I went through.
But it will not be a good solution to drill that close to the edge of a glass lens anyway. Like the link said:
_…“never drilling within 3/4 inch from any edges._”
