Sorry you confused me there with your response but it was me. When I said plastic lens I meant reflector. Better get that whip out again. Ouch.
Just bought a pack of these and my wife, who has no interest in flashlights so therefore my obsession is dumb and a waste of money, actually is thrilled with the one I gave her. She keeps shining it around the room and cant decide whether to put it on her nightstand or in her car. I finally scored a few points for the light hobby.
LOL get her a zoomie! Pick up a sipik sk68 or a clone and she will love it.
Damn
The truest definition of love for your wife ...
"here honey I got you a crap light ... enjoy !"
Interesting information Would you please provide a link to this light you speak of?
LOLOL
Anybody want to hazard a guess about the driver?
I wonder if the high and low are controlled by the resistors and if I could figure out which one is in the high circuit, I might remove it for a brighter high, with a Nichia 219 or XM-L. From the photo, anyone got any ideas??
Looks like those two 1R5 resistors are the sense resistors. They look to be wired in parallel, but can’t tell for sure. Probably does PWM for low mode.
How do I find out for sure. Is there a way to test?
You probably don’t have a meter good enough reliably to check low resistance values, so look at the pads on those resistors with a magnifier. If you can see that they are connected together at each end, then the resistors are in parallel.
Or you can try metering across the resistors. Short the probes together to get your zero-resistance value. The measure across the resistors and subtract that value. something around 0.8 ohms means they are paralleled.
I picked up a two-pack last night for $9.88…they threw them in the wrong bin! Very impressive lights for $5!! What would happen if it was dedomed? More throw, warmer tint?
They had these marked down to $7.98 at my HD.
Even better! Very impressive for a $4 light!!
I’d guess the resistors are in parallel, and the medium mode is done via PWM. While in Medium mode, wave something shiny like a screwdriver tip in front of the light. If the motion appears smooth, it’s not PWM. If you see 20 screwdriver tips all at the same time, it’s PWM.
Or you’ve been drinking too many screwdrivers… :party:
Precisely, and I recommend not waving screwdrivers around while drinking screwdrivers. Someone could lose an eye… plus you’ll look really stupid in the flashlight aisle at HD.
Meh… you got two…
I’ve got two of a few things, and just fine and dandy with keeping them all in pairs
Maybe based on somthing along the lines of the PAM2805? Similar layout, same modes. Vref would be 0.095V, however, which would put the LED current on high at only 125mA, so clearly it’s a different chip.
Link to PAM2805 eval board document: http://www.diodes.com/\_files/evbd/PAM2805%20User%20Guide.pdf
Has anyone done a simple ‘dedome only’ on these? How did you like it? The tint on one of mine is spotty…changes across the beam. I thought a dedome might even it out. Help me out fellow BLFers!
