Almost certainly, but I was using an actual driver in a light with normal batteries. I don't know of a driver that does more than 9A and I don't have a big power supply to drive it directly (I have a few, but they're all in the range of 11-16v).
Ok, I tried to repair the broken bond wires and it was a complete failure. But what is better than looking at other peoples failures ? So here we go, enjoy!:
The leds with most of the domes removed (left xm-l2, right xp-g2, same magnification), still in the Coleman to see through the silicone well. You can clearly see the incinerated bond wires (strangely they go two at a time )
I cleared away more silicone from the xp-g2 and also the bond wire debris and bended the bare wire ends are close to each other, added some solder paste and touched it with the iron. The solder paste melted and got immediately sucked away by the iron, no connection .
Added more solder paste, same thing, and also destroyed the wires. Went over to the xm-l2 led, with loads of solder paste.
Failed miserably again, destroyed the wires again, now I cleared all the debris and tried to solder what was left of the connections with big blobs of solder wire:
Actually when connected to a led tester I got some very faint light, so I tried soldering again for a better connection. Well, it ended with nothing at all, end result: dead and ugly looking led:
comfychair, are you using this 9A driver?
Does it give output 9A to an MT-G2 on high?
You do have a point though. If if there are no other drivers out there that can handle 9+ out there it is a bit limited use in knowing. But its always nice knowing how much “head-room” you might have. J)
Nice attempt djozz. At least you tried, which is more than I have though of in the past and with my recently fried XP-G2.
There are two planes on the substrate, the die is sitting on the negative plane & the bond wires jump over the little isolation trench to make the positive connection. Looks like the solder bridged across the trench. Did it act like there was a dead short, or just total open ckt?
I think the way to do it would be to try and stick a wire to the connection points on the die first, then lay them over and tie in to the + plane. The issue you'll run into trying to do it with solder is that with such small tolerances enough heat to melt solder at one end will also melt it at the other at the same time and the whole thing falls apart.
Hot air would work better, probably from underneath to keep from knocking anything out of place. If you could take a suitably small piece of wire formed to mirror the bond wires, give a light coat of paste, get it positioned and then add heat...
Added one R120 for about 4,7.
Two R120 in series (on top of the stock resistor) was about 3,65 I think. Stock output on mine was quite close to 2,8 I think…
Its basically the same driver that I modded in this messy thread. But there are a few differences. If you have the same looking driver, yours might have differences too. I have not tested it for more than a short period though, so mod at your own risk…
Edit: I have no intention of using the huge stock aluminium mcpcb in that light. Ill kinda make a cooper “pill” for a copper mcpcb to sit on… Ill might make a mod thread some time in the future…
I'm seeing consistent issues with not being able to get 3.5A+ out of an XP-G2/SinkPAD combo, whenre I can with an XM-L2, in a single cell Nanjg driver. I think you're right - XP-G2's have a higher Vf demand.
What is the amp tailcap measurement? I've been unable to get above 3.3-3.4A I believe. It still does well and bright, but just not getting the full amps.
I wonder if dedoming with gasoline weakens the wires. I know gasoline weakens some metals. I learned the hard way when I soaked a motorcycle chain in gasoline to clean it.
Or maybe the dome just physically supports the wire and helps prevent it from sagging and shorting at a lower amperage.
There are conductive epoxies that are advertised as a replacement for solder. No idea how they’d do in a high-current, high-temperature application. But it’s possible something like that might work better at repairing bondwires if you can find one with the right specs.
I took some time to put the video data into graphs, and in these graphs the numbers sure look official , watch out for good-looking graphs!!! In each video I turned the current up to a fairly high level and then turned the current down to minimal and started over again but now until *poof*, I did this to see if any 'burn-in' effect (lowering of the Vf at the same current) could be detected. It turned out that the second run both with the XP-G2 and the XM-L2 gave almost exactly the same numbers, so no burn-in effect here (Perhaps a burn-in effect will take place when the led is driven way over its maximum output).
Take notice that the output lumen estimates were calculated from ceiling bounce numbers that are derived a bit different with the two leds, the XM-L2 had a big 49mm reflector on top without lens, the XP-G2 had a small 20mm reflector on top with a AR-lens. The reflector size should not make a difference for the lux-reading, but the lens does a bit. (sorry I messed that up a bit in the experiment)
I believe that the voltage reading coming from the power supply in the XM-L2 graph -although a bit rough- does reasonably represent the actual Vf of the emitter at that current. The voltage in the XP-G2 graph was measured more accurately and directly at the (thick) led wires.
I just used the current reading of the power supply for the graphs, I did not check that with a DMM (should have done that). But for now I see no reason to distrust the current numbers.
