Basically the same as with me and others… XP-G2 seem to need two cells (and a buck driver) in order to go higher…
That's perfectly alright, I am guilty of that myself all the time.
fair play for trying I’d suggest some enameled copper wire to replace the bond wires, but making suggestions is easy when you’re not doing the work!
I wonder if dedoming with gasoline weakens the wires. I know gasoline weakens some metals. I learned the hard way when I soaked a motorcycle chain in gasoline to clean it.
Or maybe the dome just physically supports the wire and helps prevent it from sagging and shorting at a lower amperage.
I have tried once to repair a bond wire on a XML and the results were like yours…one drop solder on the phosphor and the wires still not connected…
There are conductive epoxies that are advertised as a replacement for solder. No idea how they’d do in a high-current, high-temperature application. But it’s possible something like that might work better at repairing bondwires if you can find one with the right specs.
MT-G2 is 1.5C/W which is pretty low, Luxeon T is 3C/W.
I took some time to put the video data into graphs, and in these graphs the numbers sure look official , watch out for good-looking graphs!!! In each video I turned the current up to a fairly high level and then turned the current down to minimal and started over again but now until *poof*, I did this to see if any 'burn-in' effect (lowering of the Vf at the same current) could be detected. It turned out that the second run both with the XP-G2 and the XM-L2 gave almost exactly the same numbers, so no burn-in effect here (Perhaps a burn-in effect will take place when the led is driven way over its maximum output).
Take notice that the output lumen estimates were calculated from ceiling bounce numbers that are derived a bit different with the two leds, the XM-L2 had a big 49mm reflector on top without lens, the XP-G2 had a small 20mm reflector on top with a AR-lens. The reflector size should not make a difference for the lux-reading, but the lens does a bit. (sorry I messed that up a bit in the experiment)
I believe that the voltage reading coming from the power supply in the XM-L2 graph -although a bit rough- does reasonably represent the actual Vf of the emitter at that current. The voltage in the XP-G2 graph was measured more accurately and directly at the (thick) led wires.
I just used the current reading of the power supply for the graphs, I did not check that with a DMM (should have done that). But for now I see no reason to distrust the current numbers.
Here we go:
Do you think you could do that with a Gen 1 XML? I’d donate one if needed. I am curious how an XML U3 scales, and if it can take more current at the top end.
And thanks for taking the time to do this!
Do you think you could do that with a Gen 1 XML? I’d donate one if needed. I am curious how an XML U3 scales, and if it can take more current at the top end. And thanks for taking the time to do this!
That would be interesting, and I could do that, and I do have one spare (albeith a T6), but what I lack most is time for the hobby. And to be honest: these kind of tests should be done a bit less leisurely than I do them, I am not a that accurate kind of person I'm afraid. I am hoping for someone else with time, equipment (calibrated stuff, integrating sphere) and precision to do this kind of testing (texaspyro for instance is much better equipped than me in doing these kind of tests ).
Pretty clear from the graphs the Vf tracks higher for the XP-G2 across the spectrum of amps -- wish I knew this sooner, but this sure does explain a lot.
Thanks djozz!! Great work/info!!
Dedomed XPG2 R5 3D/Sinkpad/big CPU heatsink, 1-2-3-4 cells in parallel, direct drive
Samsung INR-15Q, unprotected
1cell - 2.56a 3.61v
2cell - 2.93a 3.75v
3cell - 3.15a 3.81v
4cell - 3.24a 3.85v
Panasonic NCR 2900mAh, unprotected
1 - 2.53a 3.59v
2 - 3.07a 3.77v
3 - 3.28a 3.85v
4 - 3.42a 3.89v
Wow, that's interesting #'s. I got the 15M's and 20Q's, and the 20Q's are very good - seem identical to the 20R's, but to see them beat out by standard Pana's with qty 2 or higher in parallel, is kind of mind blowing -- not sure why? Do you know?
Also, the 2.56A for a single 15Q seems rather low - I'm definitely getting higher #'s with a Nanjg driver and 22 gauge wires with a 20Q. Mine are tailcap measurements though...
The 15Qs have been sitting a while, they were all 4.08-4.09v at the start, the grey Panasonics were just charged yesterday. Also, I only have one meter so I had to change the wiring around between the voltage & amperage measurements, could be something got jiggered. I have big fat wires on my battery box but the leads after that were single 22AWG, and the test leads for the meter are full length, something like 3 feet each, stock Fluke leads. Mostly it's only interesting in showing how splitting the load across multiple cells and the resulting higher voltage affects things.
I figured more than one INR would have killed it dead instantly, I was surprised by those numbers.
Hey, I changed my mind. I just ordered a new MT-G2 for a flashlight built I am going to do when I have the time.
This leaves me with one spare (5000K 6V) for yet another crash-test on a Noctigon board that I may do one of these days. But please give me a reason not to do this test (like: he or she has done that already and the results can be found here, or: relax !, I will do this test for you and I am doing a much better job at it than you do) because I am still reluctant to demolish a perfectly good MT-G2 .
Umm . . . I don't think anyone is going to say those things! We're waiting for you to do it! :) Thanks for these tests by the way! This is very helpful information to many of us!
-Garry
Very nice and useful graphs!
I have bookmarked this page!
Djozz, would be nice have a chart going to 10A or slightly beyond on the MT-G2. You dont have to kill it just for the sake of killing it. But if output seem to continue to rise, then I would not mind seeing what 12A would do, despite not knowing of any drivers that will do that kind of output.
There is not that much point in going far beyond 10A just for the sake of killing it. But it would be nice to know if there is some headroom left at 9A. 0:)
I agree with R86, no need to destroy it. I’m more interested in finding where adding more current results in no increase or a decrease in output. In the case of the XP-G2, this occurred before failure. The XM-L2 was still trending higher when it failed.
This information is very helpful, just don’t feel the need to destroy the emitter if the useful information has already been captured.
I probably would have tried this already if I had a supply with that current carrying capability (6A max for me).
Thanks for your efforts on this!
ok, I don't know what to expect actually, the MT-G2 is a multi-die emiiter, the combined surface area is much higher than a xm-l and the solder path is huge so if the thermal path is built like the xml2 the dies should be able to handle 20+ amps, but if the bond wires can handle that? When the weakest wire goes the rest follow directly because of increased current. Wait and see...
I don't think you'll need to kill it, I suspect the light output will fall off a cliff long before anything goes ZZZZAP.
