flatten another piece like you did to close off that end, cut 2 circles that fit inside the tube, clamp em together and bore holes for the cells, then unclamp em and clean em up, solder them with the rest of the solder job at 1/3 and 2/3 inside the tube to hold the cells in place? (a disc of copper with 3 20mm holes in it) Not only would it hold the cells, it would make the battery tube area almost crush proof!
Very cool, can’t wait to see this one all tied up and polished!
Since this is a large piece, you could solder one end and then put that end in a little water and solder the other end. If the torch can get the one end hot quickly enough, you can solder one end, while the other end is in water. Kind of like plumbers that have to solder a copper pipe while there's water in the pipe. I have also done it by sitting one end on a folded up, soaking wet towel.
Happy Canada Day!
I have added some more updates from the weekend. Some very good progress I’d say. Hopefully I will get this done soon because I’ll have no time next weekend and then this contest wraps up.
Glad you like it.
That’s just the one you can see. They will not be there long. Dish soap and warm water, followed by a good rinse and some compressed air. Good as new.
When you finish this light it will make all other lights look outdated. Love the triple emitter set up. Whens the lens due in?
On a side note some Aussie members may remember this. I think it was Street Machine mag that had a cartoon in it called Plankenum (not sure on the spelling) and his extractors on his ute from memory were made from plumbing fittings.
I was hoping to get the lenses this week, early. Coming from flashlightlens.com ordered early last week. Tracking isn’t showing anything yet, which is very strange. My IS packages usually take 6-7 days, tops. Not looking good…
Thanks for the clarification, R86. I was sure I read somewhere they were 80CRI.
Very creative ways to solve design problems. When it's done I would love to know/see what tools were necessary to accomplish all of this. For example, what did you use to cut the half inch copper pipe lengthwise?
