Love the encoder idea. I went so far as to buy a panasonic 9mm one for a future project, and haven’t got around to implementing any software either. PIC has the 18f4X31 line with hardware QEI module.
9mm encoder sounds sweet! My Alps is 12x15mm I think. Not small, but it’s decent quality and only around 1€.
But sadly no pushbutton . . .
QEI hardware interface can certainly be useful! For my manual operated encoder, a slow timer interrupt and a couple of if-then-else style conditional statements will do.
Nothing time critical going on. Only monitoring battery voltage, some buttons and/or an encoder and a timer for the dimming output. The attiny10 sadly has not enough pins for that. I think I don’t have any so8 parts left, so i’ll have to take one of my attiny44. I don’t know much about those Microchip parts, but some of them have really nice specs! Have to try them out some time.
The price is right on your encoder. Sometimes the hardware modules are overrated . And your right on the load factor, just about any flashlight driver is going to be next to nil.
The form and size of the flashlight is really cool, look forward to the build.
Thank you!
If you ever come across your encoder, could you tell me maybe the part number please?
I was looking for a smaller one for a non-flashlight related project some time ago.
Beg your pardon, it is a Bourns Inc. part no. PEC09-2320F-S0015. Check out the data sheet for all the different options.
That looks like the Ledil Lisa 2 oval. Nice choice for a cap light. Making your iwn driver, priceless.
Very interesting. I mainly deal with buck driver. I should have a try for LM3410. The Attiny 44 has 8 pins more than SO8 part, what are the fancy ideas to make use of these pins? Look forward to the new progress built.
@ nickelflipper
Thank you! That encoder looks really great! It has even a metal axle.
@Rufusbduck Thank you.
Yes, looks very much like that Ledil optic. Good eyes!
@Microna
Well, I planned to use an Attiny10 which I have in sot23-6 package. 3 actually useable pins are not enough if I want to use the encoder. So8 would be perfect, but I don’t have any tiny25/45 left unless I want to ripp them out of other projects. But I have a couple of tiny44 here, so I don’t need to order anything.
That is the best handmade DFN PCB I’ve ever seen. I would not have even tried it. Good job!
Thank you!
With a >=8 pin package I probably would have gone with dead bug style.
But this was surprisingly easy, just needed a calm hand, a Stanley blade and a couple of minutes.
If you cut in a slight inwards angle, the copper delamiates really easy.
The tiny84 lines up real nice on the proto board. Who would have thought cutting the pads in half? not me, great job.
Thank you! All those 1.27mm pitched packages like sop fit nicely on splitted pads. Speen and noise are no issue in this build, so why not use a piece of prototyping board?
Only a few days left, I hope I can finish the build on sunday, probably just in time.
It’s astounding how fast a month goes by when a deadline looms. You guys making your own drivers deserve a separate catagory based on the time you have to spend on it.
Yes, time runs quick when you need it the most.
I don’t know, doesn’t make a difference to me if the invested time is used for electronics, software or mechanical work.
Nice going dave_. I take my hat off to anyone that can solder, especially those miniature weird looking electrical thingys let alone understand what they do.
Very cool, Dave! You guys give me so many ideas watching what you come up with for this contest. I really like this little light you came up with. ;)
@MRsDNF
Thak you!
I always enjoyed soldering. Takes a little bit of practiceing for the small stuff though.
@JohnnyMac
Thank you too!
I will finish the last work tonight.
I hope I can find a dark enough place to test it and make a short video if my phone cam is able to produce anything better than noise with some shapes in it.
Great progress Dave, looking forward to seeing the finished light!
Well, time is over now, and it’s more or less done.
I didn’t got enough time today to finish the build as I wanted and additionally busted it a little in the last minutes, but yeah, that’s life.
I even forgot to add a front shot of the completed light, so I’ll do that when the contest is completed.
In conclusion, this was a lot of fun!
I rarely build mechanical things, and if I do, they are usually not made of metal. So I had the chance to learn quite a lot here! (At least that I still have to learn a lot. :P)
I am also pretty sure I never shared anything I built in a forum which makes this also kind of a novelty to me.
It was a lot of fun to read all those build threads and look at all the cool stuff. That alone made it the most fun time I had in a forum for a long long time, thank you all for that!
Any chance you could do a thread on how you built your driver? There were parts like the gas guage that I would like to understand more how it’s used and what it does. Right now it’s like watching Bullwinkle say”Watch me pull a rabbit out of my hat”, I see it happen but except for really basic stuff like linear drivers it’s all Greek to me.
I dropped most of the various parts of mine at one time or another but I think if I dropped the whole thing now it would either blow up or make a hole in the floor(it’s really heavy and solid). As with all the other mods in the contest I’ve really enjoyed reading about yours and the thinking that went into it.
