So my iphone is playing up, Graeme couldnt pick up the three c8’s because apparently I had no sim card in. Reset and 3 texts come through.
So after playing with some toys and getting the cat off my lap I decided to play with the xpg2 a bit.
Excuse the cell pics and clutter, I have 3 planes, 2 heli’s, 2 rifles and 100 torches on the go at the moment, plus leaving for a 6 week trip to US, Canada and Mexico soon so no time to keep tidy
So thats 115,260 lux at 1m at 2.85a (7x.35s and 1 .38)
was 99,000 lux at 1m at 2.50a (7x .35’s).
The driver is again Nanjg from fasttech, AR lens from fasttech, xpg reflector from CNQG (Also highly recommended), this one has no spacer, but seems to have a focal point about 1/2 way between no spacer and a spacer, so will get out the sandpaper, see if I cant get 125k at 2.85a.
I wish this Aliexpress seller wasn’t so damn dodgy, because this host is absolutely perfect. The pill height is 1mm higher than stock, so requires no modding for using no spacer. Also has 20mm recess, good switch, stepped c8 xml SMO reflector (best ive found), anodizing is good etc.
I'm running a de-domed XP-G2 at 3.85A, but only getting 125 kcd, though I think that # is low because measuring at only 4.3 meters. I used this XPG reflector from KD: kaidomain.com C8 XPG. XP-G2's just increase their output on copper with more amps - Match's charts show it increasing at 4 amps still, here: https://budgetlightforum.com/t/-/16621.
If your #'s are good and getting 115 kcd at 2.85A, I'm think'n that reflector is really awesome. I'm ordering two now... LED positioning and the reflector I've seen make big differences.
For AR lens, I got the AR lens from IOS and UCL from flashlightlens.com, though you may have issues with the thinness of the IOS lens - they were nuch thinner than the stock C8 lens in one C8, so didn't end up using it.
I think the V3 was shipping with an AR, but I had an earlier version. Convoy C8 definitely not - I found the FT AR's totally useless - no difference. Also the cheaper KD ones - same thing. IOS and UCL I trust and appear to be the real thing (UCL definite). Best bet now is maybe wait for OL to get up with his AR lens making hobby/biz - pretty much guaranteed you are getting the real thing.
I certainly like mine. I have several C8’s and this is my favorite stock C8. The regulation is incredible. On the light box it only dropped 20 lumens in 30 seconds. The modes are really nice too. I refused to buy a Xin TD for over a year because it was double the price of my other c8’s. Now that I have bought one I just ask myself why I waited so long.
Don’t have a V4 - yet. My V3 is great. My LM C12 is brighter, but the XinTD gets used more because of better modes (no strobe), and better tint (3c). And it just feels nicer in hand. Yes, it cost more, but still seems worth it, IMO. The new 5B tint option sounds fantastic to me.
Hi Jacob, and welcome!! The Convoy C8 pill is a one of a kind - not standard C8 pill size threads, and it's designed for 16mm stars, not 20mm. The body is a quality C8, but the non-standard pill is my pet peeve with it. I bought it as a host and built a de-domed XP-G2 out of it.
Jacob: Aluminium is a BETTER thermal conductor than brass. Brass is generally what the ‘chinese’ call copper. REAL Copper is a better thermal conductor than aluminium so if you find a pure copper pill then, you’re in a happy place
jacob, fasttech has an ultrafire c8……I’ve dropped one in my cart because it MIGHT take the c8 pills they have, its very cheap for an xm-l c8 and I only plan on using it as a host, I’ll report back
“_So thats 115,260 lux at 1m at 2.85a (7x.35s and 1 .38)
was 99,000 lux at 1m at 2.50a (7x .35’s)._”
I see 1807 from the lux meter, please advise how you got 115,260 Lux.
Also on your first post, you have 68,200 Lux at 8M, is it 68,200 data from the Lux meter at 8 meters?
As discussed on A Little More Machining Video, pure Al and Cu are too plastic for practical machining, and casting is not a practical alternative for a budget light. It might be possible to forge a soft metal pill, but not without a lot of development. So we are talking about relatively pure alloys that are machinable but still good conductors versus alloys like aircraft aluminum and brass that are optimized for machinability and strength.
The Wikipedia article on 6061 aluminium alloy says “The typical value for thermal conductivity for 6061-T6 at 80°C is around 152 W/m K.”, whatever those units are. For pure Al, it lists numbers around 220 in what appear to be the same units, in the article List of thermal conductivities. Pure copper is around 390 and brass 120 in the same table.
So brass is nearly as conductive as hard Al alloy and suitable for pills when it is easier to fabricate, while alloys with higher Cu content have superior heat conductivity.
Heat conductivity of metals is loosely related to electrical conductivity, so alloys used for ground busses and such in electrical devices are good.
