LOL. DD have lost the plot.
Edit - Oh, and nice review, thanks.
In the picture zebralight is in mode H2(172 Lumens), but the H1 would 280lumens (of course 280 zebralumens are not really 280 lumens)
At least not green thanks for the review!
Hi f42
The SC52 in the picture looks very greenish, the camera is not good, but really does not look so green.
I also prefer the Xtar tint.
If you didn’t take two different shots of lights one by one and merge the pictures, it is not because of the camera I guess.
Tint of xtar definetely looks good!
Nice review.
Which would you recommend out of this and the Sunwayman C15A?
Both look very interesting to me.
In OP it was mentioned “Zebra 14500 and Nitecore NL147 not work with it”. May I ask why? Size problem or other issue? Thank you very much!
Hi
It is a difficult question ; C15A or WK41.
The newest is the WK41, but consider several things.
- Low battery warning light: in Xtar alerts with NiMH, Alkaline. In C15A alerts with 14500.
EDIT: Xtar alerts with NiMH and 14500 (and alkaline and L92)
- Cut to 2.75V battery in Xtar. In sunwayman i do not know.
- Compatibility 14500: In C15A the Nitecore NL147 works well, the 14500 Xtar works well (zebra 14500 not work) … is very compatible. In Wk41 the Nl147 not working, not working Zebra14500, of mine just goes with the XTAR 14500.
- The reflector of the C15A is smooth(more throw), the OP of Xtar more floods.
- Size: the Xtar is lighter and better EDC.
- Interface and sharing modes, better Xtar. Tint is colder in Xtar, in C15A is almost neutral.
For a little, I think I prefer the XTAR WK41. When I have protected 14500 battery that fits well in the Xtar, then be my favorite.
EDIT : VIDEO Sunwayman C15A battery 14500 / Xtar WK41 battery 14500
The problem of “14500 zebra” is that it is “flat button”, and physical protection Xtar is avoiding contact.
About NL147, I’m not sure. I think the size is not the guilty. This is Top Button, but protrudes very little (i think this is the reason). The positive in the Xtar 14500 is the same as in the eneloop or alkalines.
Hey nice review. Good use of text in your pictures.
Thanks for a great review Trevi_lux, very much appreciated
Nice Review! I like that diffuser- I wish every decent light came with one, that was similarly styled. It helps turn them into nice camp lanterns.
Thanks for the video! On a NiMH the 150 lumens seems too low. They should have got it up to atleast 200 lumens
Hi.
True, but they have tried a good balance Lumens-Runtime.
Not a big flashlight to use outdoors, but as EDC is enough.
These 150 Lumens, light as well as 170 Zebra or Sunwayman lumens.
Just wanted to say thank you for the excellent review. I bought one earlier this week specifically because of reading this review and it just arrived today. This is by far the best EDC flashlight I’ve ever owned.
I’ve been using it with the Eneloop XX 2400mah AA, and I wont really get a true opportunity to test it till tonight. But this review hits everything spot on, its small, lightweight. The quality is top notch, one thing I noticed in particular that the threads when removing the battery compartment have INCREDIBLY smooth action. And in event of a zombie apocalypse you’ll have a flashlight that will take any AA battery you find laying around. I may venture to try a 14500 battery at some point but the Eneloop on turbo (4th setting) really does put down a lot of light, so I’m not in any sort of rush.
Two other notes, the Strobe is pretty easy to learn so if you have to use it for self defense; its very accessible with 2 quick taps, and you will hit strobe every-time whether the light is on or off. Also the memory works fantastic too, so if you leave it in high its in high mode when you turn it back on (also great for self defense as well).
Overall this is the best $40.00 i’ve spent in a while. Its probably the most expensive flashlight I’ve bought prior to this I’ve only had crummy nebo & ebay-amazon-generic cree flashlights. And It has absolutely been worth every penny! Xtar has won me over!
The only mild disappointment was the difficulty of finding these, I had to order it on ebay (new), I guess I just get spoiled with ordering with Amazon Prime though!
You’ve been using it a few days. Are you happy with it?, I did not get out of my pocket 8)
Thanks for a terrific review, Trevi_lux. In my country there is a local distributor for Xtar lights and I’ve already ordered the WK40.
However, after reading your review I may have to buy the WK41 as well :8).
I am 99% happy with it, only one pretty minor complaint (see cons)
Pros
Cons
If the C-Clip gives me any trouble aside from what happened already I may try to design one up in CAD to get 3D Printed, maybe something with a screw/set screw based fastner printed in stainless steel. But for now its only fallen off once(which I’m hoping was just an odd unlikely scenario), which I can deal with, its really only a problem if it starts regularly falling off(If that ever happens I’d definitely post an update as well).
