Pretty sure it’s an 85mm bezel, so the reflector is around 70mm I’d guess. 150mm is the length.
yes… if the reflector is 150mm, the lenght should be 40cm or so… impressive light, for sure
UPz:I like this one better than the YL-U2:
SolarStorm SP03
It has 3x XM-L2 and an impressive 150mm reflector. I like the battery configuration and it really looks like a good piece for modding/swapping driver.What do you think guys?
Specs say it is 85mm head, 77mm reflector & 110mm wide counting the handle
Damn, I was really hoping the larger switch was a "master" clicky switch, and the smaller switch was momentary for changing modes. Unscrewing the body slightly on the SRK to prevent battery drain is kind of hokey to me.
Damn, I was really hoping the larger switch was a “master” clicky switch, and the smaller switch was momentary for changing modes.
Isn't that what it is???
-Garry
JonnyC:Damn, I was really hoping the larger switch was a “master” clicky switch, and the smaller switch was momentary for changing modes.
-Garry
The UI says to press and hold the large button to turn on/off, or maybe just to turn off? Either way, it's an electronic/momentary switch :(
Big button 1sec to go to first mode, second click to high mode.
Small switch is momentary on, High, release it and it's off.
Threads are anodized and therefore a twist to the head and it's a lock out.
When in 1st mode, you can use the smallest button to let the light start ramping, and stop at your desired output.
This will memorize the setting.
That's how it worked with my L3, so I guess it's the same.
Low PWM.
I'm still confused.
-Garry
Sorry that it wasn't clear enough, where did you get lost?
Oh, so the big button is a "Power" button - hold a sec to turn on & off. Tap to change between "first mode" (your memorized ramping level) & then high. That it? Another tap to go from high to the "first mode"?
-Garry
That's basically it.
Big power. Small for ramping, and momentary on.
Only 2 modes. Same as SRK, except you can change the desired output.
If it had 3 modes that would be a big plus, but it doesn't, and pwm low is probably as low as the SRK.
they might have changed the UI, but I guess it will just be the same..
I'd swap those buttons if I get one.
I don’t know why so many people are turning up there noses because of the blue buttons. A button swap probably costs 42¢.
Not because of the color, but they really feel squashy.
It feels wobbly, that's all. I don't mind the color at all.
It's also adding the difficult part of changing the driver if desired. 2buttons vs 1.
If you use TP’s new driver you can just not use one of the switches. Just because it has two switches doesn’t mean you have to use them.
True!
will texaspyros driver fit in this light?
Has anybody received theirs yet? Just found a package in my mailbox.
Nope, still waiting.
Would be nice to get some update on this light before Pulsar closes his GB for M6…
Any thoughts on parasitic drain?
P.S. SolarStorm warrior II @ WB is now 53.03$ WTF
