Very nice beam shots! That’s a great place to do them in. I have nothing similar to that where I live.
JohnnyMac, have you compared to SRK and does it out-throw it? It appears to. Completely agree, the variable output option makes this light way ahead of a standard SRK and Kung even with around the same output, and if throwier, adds another bonus variable to the mix.
I’m highly interested, but I’m kind of holding out for a NW version. Any news from FastTech by any chance about the possibility?
I’m sure some forum member could easily neutralize one for you.
I had it in my shopping cart until I saw your comment about the PWM on Fasttech
Maybe I’ll get the SRT7 instead.
No reply from Jasmine, SB. She has been MIA this past week.
I did not. Sorry.
I will add that this has momentary on and the SRK does not. ;)
Well go do it, its almost dark!!! Yeah momentary on is nice to have too. I already prefer it to SRK and I dont have one yet…and after my experience with ordering a Kung, I can only recommend it if it comes with “-pao chicken” after it in a nice Chinese restaurant.
Warrior seems to be an evolved SRK with cool features but the PWM turns me off from it.If you don't have a light of this form factor yet,I think it's a great deal.Thanks for everyone's input on the warrior.
Thanks JohnnyMac. I wouldn’t have been able to post the pix without your thread on adding pictures to posts, and garrybunk’s tip on Photobucket links.
Fasttech site has been saying these would be back in stock July 31. Now on July 24 they are already back in stock, just ordered two more.
Mine arrived while I was away for a couple of weeks. I returned last Sunday, and one of the first things I did after I kissed my wife, was check it out. Fantastic light! I hope this second shipment is as good as the first. Someone who has received one from both shipments needs to reassure us that they are just as good, as I would like to order more.
JohnnyMac. If Fasttech is willing to get 3C, XM-L2 versions of this light (in a reasonable time frame ,) I’m in for one for sure!
Also, did you open the light? How does the heatsinking look? Thanks.
Mine arrived today. Freakin sweet! Puts out between 2150 & 2200 OTF. Hotspot is super sharp compared to the King and it feels much smaller than the King. Threads are clean, deep,smooth as butter, and fully anodized so you can lock Iit out for zerp parasitic drain. Just 5-10 degrees locks it out. The buttons are smaller than you think so good luck finding replacements if you dont like them. I like it better than the SRK stock. The ramping feature lets you choose any output level for your custom mode. Long press turns it on and off so you don’t have to cycle through the modes to turn it off. Maching is clean and crisp. The ano is even and consistent. The reflectors are clean and smooth. A real bargain for $35! I almost forgot to mention the AR coated lens.
Given the current draw of 3A, I’m surprised by the output. Can you measure current draw for us? Thanks again!
Performance and beam sound similar to the T60CS, but that about half the price.
Loctite yes/no?
No loctite, battery carrier unscrews from head, bezel unscrews from head, the rest of the head is one piece.
I notices that Fasttech sells both Fandyfire and SolarStorm SP03 and the declare the FF to 2 000 Lumen and the SS to 3020 Lumen. I vrote their customer service and asked them to explain the difference and they replied to me quite fast: “We will test the items and confirm the information, then we will update to you, thank you for your patience.”
Good service, I look forward to the result.
I notices that Fasttech sells both Fandyfire and SolarStorm SP03 and the declare the FF to 2 000 Lumen and the SS to 3020 Lumen. I vrote their customer service and asked them to explain the difference and they replied to me quite fast: “We will test the items and confirm the information, then we will update to you, thank you for your patience.” Good service, I look forward to the result.
They both do around 2200 OTF. The Solarstorm specs are grossly exaggerated and the Fandyfire specs are a tad reserved.
I just received my Warrior with XML2 from Rik’s site for $45, and my first impressions are very good! Other than the slightly longer shipping than expected, which is probably due to a customs inspection (damaged box with yellow tape on the external envelope and internal envelope, post tracking shows it sat for a few days on entry into the US). It is slightly visually brighter than both the SRK and Kung that I have via daylight white wall bounce, the center hotspot is definitely more concentrated, with slightly less flood spill than the SRK (a lot less than Kung). It feels somehow a lot smaller than SRK, although it really isnt THAT much smaller, but the difference in feel in the hand and the pocket is definitely better. I also really like the variable output and momentary on (though I’d prefer to be able to manage momentary on time manually).
Without Texaspyro’s driver, I’d say SRK is eclipsed by this for sure, and Kung (if you can find a reliable dealer) is better for floody output, but if thats not what you are looking for, this outdoes Kung as well. Even though my total price each in the end for both SRK and Kung is less than half, I already feel like I’m going to be using Warrior when I dont want a long light to hike with at night.
Could it be that it is now a 5 mode?
FLASHLIGHT MODES Hi > Mid > Strobe > SOS > Infinitely variable brightness
LENS TYPE Glass Lens
MODE COUNT 5
MODE MEMORY No
REFLECTOR TYPE Aluminum Smooth/SMO
SWITCH PLACEMENT Side
SWITCH TYPE Reverse Clicky
TAIL STAND Yes
TAIL-CAP CURRENT 3000 mA
