C8 addicts thread
No worries buddy!
Chris
wich AR lens for C8 besides de UCL?
kaidomain? fasttech ? IO ?
anyone has review of the other 3 ?
I have a Convoy C8 with a Qlite, a Xpg2 on a noctigon and an AR lens. Today I got a duel stage Xpg reflector to try out. Unfortunately when I put the reflector in the emitter was pulled off. I think the hole for the xpg is so tight that it caused the problem. I would like to replace the XPG and try the reflector again but don’t want to have the same problem. Any sugestions?
I just built an XPG2 C8 with OP reflector from KD and a 5xAMC driver from FT. Well after tweaking the pill height vs reflector it gave out a bright and well focused beam. Smooth too. I don’t have a lux meter but after a try outside, C8 vs Armytek Predator 2.5, I can’t say C8 is much behind of Predator. So it appears the $60 difference is all for the build quality I paid for Predator. I feel somewhat guilty. :slight_smile:
I can justify $40 quality light vs a C8, due to better builds, water resistance, body strength, modes, efficiency etc. But if you want a small size thrower, a C8 can still beat the lights a few times more in price.
I was wondering have any of you guys found a replacement tail switch for the c8 that can handle higher amps? I have ruined two of them with a build I am doing with a red phlatlight direct driven from ncr18650pd battery.
mhemling, see this thread.
:beer:
Thanks for the link!
LMC12XML2 today. And partly because of your short review and posts. Thanks Tim
got my first c8 the other day, the banggood 8.88 xml t6, and i like it.
its bright, throws well and has usable spill, the only downer is a hollow pill?? star only sits on a small edge so i wouldn’t run it on high for a long time. oh and the next mode memory, i hate it its s frustrating its my first light with it |(
i also have the convoy c8 on the way. im very interested to compare the 2
I have both the C8 from Banggood and the Convoy. You will be much happier with the Convoy. The quality is much better.
for 8 bucks i like it :bigsmile:
i just posted in the bangood 7.99 c8 thread, im interested to see weather yours has a hollow pill and what amps yours pulls on high?
I agree it’s not bad for 8 bucks. The pill is hollow and I pulled the switch out and it looks kinda cheap to me. I tried getting measurements on high and the best I got was .87A but my DMM is a turd from HF so I have no idea if thats acurate.
The XM-L2 U2s finally arrived so I stuck one in direct drive in a C8:
Stock C8 (Ultrafire, XML on Alu board) was ~22K lux (700-750 lumen)
With XM-L2 U2 on copper:
Before de-dome was ~42K lux (1300-1400 lumen?)
After de-dome is ~85K lux
After de-dome without the front lens is ~95K lux
Current reading was ~3.5 amps but probably closer to 4 without the DMM… I will try compare lux readings with and without the MM.
Over 10% is lost due to the front lens alone, time to get some AR coated lenses (99% transmittance) for them I think as well as better switches (shorted the battery and got a puff of smoke from the one I was using)
Will stick up results for the C8 XP-G2 once I get around to piecing it together.
Manual,
When you say direct drive, meaning VBat+ on LED+ and VBat- on LED-?
and wow! 42K, 85K and 95K lux! Is that 1 meter to a Lux meter readings?
:beer:
Yip… other then the switch and contact board the battery is connected strait to the LED. Measurements were taken at 4.56m so multiplied by 20.8 to give lux @ 1m.
I've gotten about 100 kcd on a full mod'ed C8 (XM-L2 U2 de-domed, Nanjg driver w/extra 7135's), and up to 142 kcd with a de-domed XP-G2.
Did anyone noticed this:
UltraFire C8 SST-50
wow. u doing any custom work again? :slight_smile:
I'm trying to catch up - still got a TN31 and 3 Shockers to do, not to mention so many of my own lights/projects... The magic #'s are at or close to 100 kcd for C8 class, and at or class to 200 kcd for HD2010/SS T08 class lights. It's been pretty consistent like this for the full set of mods -- maybe 95-100 or 190-210.
