You can probably see that the light moved during repositioning.. I did it on feeling.
so I had to add them all in Layers in GIMP, and repositioning them one by one, so they would be on the same position between the shots. But the background moved... so I tried to crop a bit... but thats why a white background would have eliminated that problem
The regulation is very evenly spaced, seems to be logarithmic and adopts well to the reception curve of the human eye. There is no “dead space” - maybe the last 2 degrees at full don’t do much, but i think it’s ok. The only complaint i could think of is: The ring has, although very little, axial play. You can push it, maybe 2/10th of a mm back and forth. I’m suspicious, that some grind or dirt may get inside and interfere with the smooth operation of the ring. I don’t know, time will tell. :~
It looks like the background moves, resulting in the V11R sliding to the right. I guess either you’re not placing the V11R exactly in the same spot for each picture or the lighting changes.
Just looks kind of weird because I’m expecting only movement in the V11R and a static background.
Wow, what an awesome review ChibiM! Is this your first review? I especially like the GIF which is probably a first here on BLF but what would I know since I rarely am online anymore.
