Aloha and welcome to BLF mazda96hatch!
Is a Trustfire ST-50 with a SST-50 emitter. http://www.dealextreme.com/p/trustfire-st-50-sst-50-5-mode-1300-lumen-memory-led-flashlight-2-18650-36031
From reviews I've seen it is very fussy about battery quality (Shuts down after a few minutes on blue/grey Trustfires), and some have had driver problems.
The 'SST-80' is a myth.
SST-80??
I just got a Masterpiece Pro 1 and I'll tell ya what folks; if you think the "lowly" XR-E hasn't got game, you need to see this thrower do its thing. A full review is coming (I'm waiting on an F15 to come for my big thrower contest) but suffice it to say this one hell of a nice flashlight.
Foy
Hi there mazda96hatch, thanks for joining BLF! We're glad to see you here.
The Solarforce Skyline 2 is the throwiest flashlight I own. It's a tad bit on the expensive side though, around $28 IIRC.
Thanks for the warm welcome.
Here are some pics I took last night. (be kind...first time)
Wall at 1.7m. SST-80 with aspheric lens on left, Trustfire X6 center and K8 right
K8 hitting tree in next street
K8. You can see most detail of the tree.
SST-80 with aspheric lens.
SST-80 is much brighter.
Trustfire X6.
X6 just puts out masses of light.
Although blurry this what the SST-80 looks more like to the naked eye. Really stong beam.
This is a shot of my TK41. It's not exactly 'budget' but it's truly an awsome light.
As far as the SST-80 goes I can only go by what is written on the side of the torch, although it does look identical to a SST-50. As you can see the K8 does a mighty job especially for the low cost. My son likes it because it looks like a light sabre when he shines into the night sky.
Hope this helps you a bit.
Great pics, Mazda! Thank you for sharing them. That X6 does look nice.
nice expensive light there! but beware of the X6, someone got this beast exploded https://budgetlightforum.com/t/-/1279
Uh, that light was off when it exploded.
I'm probably insane... but I want one anyway!
Rich
The best controlled result I’ve obtained with my UniqueFire HS-802 was 500m (measured from map).
Granted, it was in the clearest air, moonless night, and the target was a light-painted house which I could then just make out against the dark background. From our window, there is another suitable house 450m away and even my unenlightened wife could see it without any adptation.
My sample, equipped with an XR-E R2, draws 1400mA from a fresh 18650, so it’s slightly overdriven. That being so, I’ve never tried to power it with 2CR123 or even 2RCR123, which, according to the specs, could be done. I don’t want to push my luck as I need that light on my regular night walks to determine whom those reflecting eyes in the distance belong to (whether it’s deer or brown bear).
Thanks for the warning Hansheng. I must admit I probably won't use it a great deal because it's like walking around with a cave mans club.
It's almost impossible to go wrong with the HS-802 for the price. It's easy to see this light does not (and never claims) to put out a huge amount of light, but the percentage of light concentrated at that hotspot is crazy. Just snapped this beamshot for you with the iphone, so please forgive it's blurring of the hotspot. In reality the hotspot on the wall from ~10ft is 2-3 inches max. Outside, this thing is just a beast, but I don't have any good shots for ya.
To add, my light sounds severly underdrive compared to other results I've heard. With a fresh Trustfire flame 18650 it pulls just under 1A. As said above, this light can handle up to 9V, so 2xCR123, or if you can find an extension tube it could handle 2 18650's.
Trustfire Tr-1200, 5xQ5 on the left. HS-802 on right
Recommend a thrower for my friend for hunting purposes.
it sould be 2x 18650 maybe to fit to glovebox.
Needs at leas 1 hour runtime on high, at least two modes.
Should throw perhaps 200m or something like that. Not looking for smallest spot so I quess XM-L is ok.
Sky Ray STL-V2.
Checked the Review on this, seems to fit the needed specs quite nicely.
DD has that discount still going on :o I must see if I dare to take it from there, would be a good budget deal!
Any idea of how far this throws? I bet it out-throws my only good reference, 980L, but by a how big margin?
I know 980L is not terribly far to reach 200m.
Defining how far it throws is hard... I'd say 200+ meters quite easily if target is light colored.
And you know Finnish autumn weather isn't best for testing it...
Looking at this post on the review thread might give you some idea about the throw:
SkyRay STL-V2 Reviewer's Overall Rating: ★★★★★ [image] Summary: Battery: 2x18650-3x16340(18340) Switch: Forward Clicky Modes: Hi-Lo-Strobe or H-M-L-Strobe-SOS LED Type: XML T6 Lens: Glass Tailstands: Yes Price Payed: $54.75 From: Manafont Date Ordered: 6-24-11 received 7-7-11 Pros: Really bright spot beam with no noticeable donut hole Wide deep SMO reflector. 60mm wide by 40mm deep. Excellent build quality and machining. Led mounted on 30mm x 2mm aluminum …
Yeah, somewhat. IRL it's brighter, my PNS just ain't best for capturing it right.
