Review: TrustFire R5-A3 XP-G R5 1xAA 3-mode
Hey Don do you remember the infamous Energizer 2500's......charge them up and discharged within a day and thats with the cells not being used. Those cells were truly crap, now the only ones i like to use are the 2300's and 2450's since they hold a charge longer.
We never got those here - first time I ever saw Energizer rechargeables was a couple of years ago - they are all over the place now. The only ones i have came with an Energizer 15 minute charger - aka "Death to all cells". That thing bungs more than 8 amps through the poor cells and kills them in 30 cycles. And that's with good cells.
I had some Vanson branded 2300mAh ones that were just as bad. In two years 10 of them couldn't run a 12V PC fan for more than 5 minutes - that fan needed less than 100mA.
I guess we all had our share of bad cells........
That's for sure! There are still loads of really bad cells out there that put people off rechargeables for ever. In the 80's I had no choice but to use rechargeables even the not very good ones available then - 300mAh was a high capacity AA then. Been using them for everything I can since.
What got me was that i had a lot of those cells and i always wondered at the time why they sucked. Nowadays i know better on what cells to spend my money on, but rechargeables are the way to go in the long run.
Do you reviewers with 1.2/1.5 NiMH also have 14500s? If you have both, please comment on whether there is a point to using the NiMH cells.
Generally if I can use 14500 I'll default to them. Ty
I like to use both because one will get longer runtime with a high quality nimh cell then with a 14500, now if you want the light to be brighter then go with the 14500.
Welcome to BLF Meester.
A lot of lights with a 14500 get far too hot. Depends whether you need a lot of light for a relatively short time (and burnt hands) or less light without burning your hands. Any light that gets too hot to hold is going to get the LED and driver even hotter which does not augur well for longevity.
I wanted to make sure there wasn't comparable brightness with NiMH that I was missing. I like having the options for bright and long runtime that come with multimode lights and that is my default approach. I was willing to give up some bright with my Romisen RC-I3 with what may have been a P4. It ran preety bright and after I opened it up to a 17500 it was about the best I could expect in a single mode. I love those 17500s. Now that I've lost it I'm looking to replace it with a multi-mode R2 or R5 EDC. I just ordered the UltraFire A10B Cree R2-WC HA-III 5-Mode 250-Lumen LED Flashlight (1*18650) http://www.dealextreme.com/details.dx/sku.29096. It doesn't look too much bigger than most AA lights but with those modes and battery it may be just the ticket.
I had one of those, didn't much care for it. It is quite small though. There is a review of mine on Jayki.com here
What do you think? Is there room to open uop the walls?
TY, meester
I don't think so, but will dig out the measuring gear and check. The plug nature of the tailcap would probably make boring it out difficult.
Hello there Meester, welcome to BLF! Enjoy your stay here.
I agree with Al, if you want long runtime and decent brightness on High, then use a NiMH or even an Alkaline. If you want even more brightness and you can sacrifice some runtime, use a 14500. I personally don't use 14500, because I need long runtime on low more than anything.
18650's in a light would be the ticket since the capacity of the cell provides long runtime and high capacity. I would like your impression of the light when you get it, and why just the 17500 format.
so I may be moving on from my interest in 17500s. Anything I wanted in a 17500 i get double in the 18650s, with just a bit of extra size.
Though- I wasn't aware of the Akoray AK16! I like the Akorays and would probably have bought one of them (and tried to get a 17500 in to it)
Thank you for the reasoning since i dont own any cells of that format..........
I received this flashlight today. it seems very good quality. In fact i think that it is my best quality budget flashlight. Most certainly better that Ultrafire C3 and stainless steel version. It is gives about same brightness with alkaline that Ultrafire C3 with 14500. If used with 14500 its even brighter. This will be my next EDC flashlight hands down!
Highly recommended! +++++
Good, I'm glad you like it. It certainly is a high quality instrument, and ridiculously bright even on 1.2V NiMH. I wish that shipping wasn't so expensive from here to anywhere else, because I would sell mine for a song.
It is a nice light. It would be an even better light if it had no strobe and a low that is about a quarter of what it is. But the sheer brightness is very impressive. On a 14500 my one makes around 362 lumens at switch-on, 329 lumens at 30 seconds and 315 after two minutes.
Why? Don't you like it ?
