I’ve got to get me a hd2010 to play with……more to the point, I need to have a play with my light meter, want to see what my l2 is doing before I go full retard on it and its twin…….
I too got an x3 hi cri……mrs gords loves it as a bedside/spotting light, its the first one she’s taken an interest in, guess she’s a tint/hi cri snob, who knew? I’m now wanting to get “her” an xintd c8 v4 same driver/emitter as the x3, I’ve put it off for too long.
Worryingly, I have a supfire m6 inbound, I’m already looking at hi cri xp-g2’s on copper for it, I figure a doctor Jones driver and two 3.1a slaves to match should be good in there……I’ve not even got the damned light in my hands and I’m already modding it lol. And that’s ignoring the small pile of cheap lights I already have to mod, this place is a bad influence lol
I’m just going to direct drive it to keep it simple. I’ve tried an MTG2 P60 DD before off 2x 16340 IMR so it should work. I’ll make another thread if the whole thing comes together.
I made some measurements and calculations to get the total mating area between pill and housing of my C8, C12 and XinTD V3. Surprisingly, the C12 with it’s larger pill and more threads had the least! The narrower flange and sloppier threads are to blame. Keep in mind, the area actually making contact is going to be less because of the typical surface imperfections. The 2mm wide flange contact only left a 1mm wide mark on the C8 so, in reality, the C12 is better but with a TIM, the C8 wins. For comparision, I added a the approximate area of a 20mm star. The C8 and C12 are from DanceLite.
Hi Tom.
Previously I was only getting 29kcd until I tried a different battery from a laptop pull. This is a CGR18650DA and getting around 40kcd on a XM-L2, 12x7135 and Nitro sink pad.
What value were you getting before de-doming the LED?
Both springs with wires (instead of braided wire). What other mods I can do in addition to de-doming to get close to 100kcd?
Before de-doming, about 45 kcd, one as high as 50 kcd. I always use a UCL or high qual AR lens. So, you have a 4.2A Nanjg (assuming 350's) - are you measuring 4.2A at the tail? If not, you need a better, lower resistance cell. best is Samsung 20R, but a 20Q or Pana PD, or SONY 30A may achieve it or come close. When you are over 3 amps with a Nanjg driver for an XM-L2/copper, you need a low resistance cell.
Hello folks, this thread is very informative, thank you all.
I have my parts list put together for my first (this in-depth) build and my first C8, I have a few questions. I am going to buy a convoy C8, from what I’ve gathered from this thread its about the best starting point without going up >200% in price. This is going to be a dedicated thrower that will be used sparingly an rarely turned on for very long at a time. My biggest concern is a good single mode driver I can stack 7135’s on.
I had planned to use this nanjg 105c but I’m concerned that I won’t be able to stack 7135’s on it since its non-PWM. Is that wrong? I see it uses 7135’s but I read over at CPF that stacking chips only effects the PWM levels. If that’s correct can someone recommend a single mode driver that’s either ~3.4A (what I want it to run at) or less that I can stack on. If there is a good 3.4A single mode driver I’d rather just do that to save on the tiny component soldering.
This is my parts list, does it look like everything I need?
From FT (Sku)
Convo C8 SMO ( 1272100)
Bare 7135 chips (1197600) ( if the exact driver I want can’t be bought)
You can stack 7135's on that driver, no problem. 7135's act as current limiters. For example, if you add 3 350 7135's to bring the total to 3.85A, then 3.85A is the max limit but does not guarantee you will be at 3.85A, you could get less because of voltage drops from resistance, resulting in less amperage. No idea what they could have meant about stacking chips only effect PWM's -- maybe one particular, weird driver? PWM's I suppose you could say are effected because all modes are effected: Hi, Med, lo, etc... Hi usually has no PWM's - PWM's are there as a cheap (digital) way to implement medium, low, moonlight modes.
For that fwd clicky, not sure how you would go about mounting/fitting that - dunno, maybe you researched that already. By UCL, you mean AR lens I assume - only place I know of to buy a "UCL" lens is from flashlightlens.com for a bit more $$$.
By AS, we usually use AS5 (Arctice Silver 5), generally thought to be the best for the cost. Also, I always use Nyogel (here) on the threads with o-rings - I swear sometimes it even boosts output, but not sure, but never seen it hinder output either. You may be able to find it somewhere cheaper, dunno.
For that choice of LED's, I assume you are aware you will get significantly less lumens, but get a nice warm white tint (T3 vs U2 bins, 4 bins separation).
The list is impressive!
Oh Note: Those 1 mode drivers are funny - no micro, no low battery warning or auto shutdown, just 7135's on a board basically. For $4.15 cost, while from FastTech, I've bought dozens of these: amc7135-2-group-25-modes for $2.68 at qty 5, and then program them myself with any modes I want.
One More Note: You could buy the Convoy C8 as a host, but you'd have to buy an SMO reflector separately, still little cheaper though.
Hey thank you sir, I didnt know the SMO reflector was avaliable, I originally looked at the host only but wanted SMO, I’ll search for it now and go that route. I would prefer to use one of those drivers you linked but I didnt think you could make them single mode only, can you? As far as the switch, I hope its right, I found it from a thread linked earlier in this thread, even if it won’t work on the PCB I should still be able to use the forward clicky and I actually needed one of those 20mm PCB’s a few weeks ago so it’ll be a welcome addition to the spare parts bin, those boards are relitively hard to come by when you need one.
As for the lower lumens with the warm white T3, I always prefer the <4000k tints, I have T3 XM-L’s I’ve swapped into a few lights and I love warm (or at the very least neutral) tints more than I care about the slight increase from a cool white emitter.
I can make them single mode by re-progamming the Atmel TINY13A, but actually, I never built a single mode version because with mode memory, never felt the need, but maybe with a fwd clicky it would be more applicable.
Well according to this: http://flashlightwiki.com/Cree, difference between a T3 and U2 is 300 lumens at 3 amps, bigger difference at higher amps. I'd consider ~350 lumens a pretty big chunk and will make a pretty big difference in throw, but that's the trade-off. It's a shame with the technology now we have to pay a performance hit for nice tints.
White ring on switch boot is a soft plastic spacer, otherwise tailstanding is a little wobbly. I think the black spacer came from a different light but it's a pretty common part, it came from the leftover parts box. Add flat washer/s for shimming if needed. This one still has the raised nubbin thing inside the switch boot, if that were shortened or trimmed off completely it wouldn't need the flat washer, but the tailcap stack height is short enough that the tailcap seats fully against the battery tube so I don't do stuff like that to gain extra space if it's not needed.
On some of the smaller lights space is so limited with the tall forward clicky switch that the threaded retainer has to be omitted, with the switch PCB sandwiched directly against the rear face of the battery tube.
