Thanks for the kind words all.
Night shots added to the 1st post.
Thanks for posting some beamshots MRsDNf. That thing looks to be awesome. It doesn’t appear to be a great thrower but the beam is very even all the way out, no rings. The color looks good too. I have got to get me a couple of those MT-G2’s.
Thanks again.
That is one serious light there! Another one of your beautiful designs. I am really jealous of how neat you are able to get the finish of your lights, love it!
Quick update. I hate to say this but the light developed an intermittent fault. One of those ones where if you whacked the head of the light hard into your hand it would work again and stop the light flickering. Some may laugh at this but l nearly cried. Yes my soldering has let me down again. Just when I think I’m getting better at it it turns around and bites you. The problem was traced to either the negative or positive strip on the star to led connection. I have since replaced the led which still works fine but thought I will put a new one on just in case. The star is starting to look decidedly second hand now with all the heat put through it. I used solder this time instead of solder paste on the led to pill/star junction. A new driver is being installed not that there was anything wrong with the old one, which will I hope boost output a little. Hopefully it will all work when I get it all back together. l’ll update when its all back together and working.
Sorry to hear about the connection issue. Hope your changes give you a nice boost.
I would like to add your light to the MTG2 throw thread. Is the 47334 in Post 12 above the actual lux reading from the meter or is it calculated cd (throw)? I'm guessing its the calculated throw (lux x distance squared) because 47334 lux at 8.6 meters would be 3500kcd.
By all means add it. It was calculated back not that I’m an expert on any of this. I had help from another member here.
Thank you
New pictures added in the first post with the 3C now sporting a IOS 9 amp 3 mode driver. This driver has transformed this light from a light that was did not impress at 120 meters to a light that literally goes look at me now at that distance. To say I’m blown away with the difference would be an understatement.
Yayy! Thats more like it! :)
How many batteries are you using??
And how does it seem to handle the heat?
Thanks RaceR86. I’m running 3 26650 batteries with a spacer. If it works ok I will shorten the battery tube. I haven’t completed any long runs with it yet so I’ll report back when I have. On the light meter it has not increased a tremendous amount but in reality its like the extra current has woken it up. Nothing has made much sense today.
You did really fine job. Very nice flood light and natural looking tint. 18 AWG wires?
But I am not sure about Fujik potting any more. It is pretty messy compound.
Holy crap! that 9a driver did the trick!!
Wow! Now that's the kind of MT-G2 light output I want!
-Garry
Wow oh wow! That is just awesome, awesome, awesome. Congrats on your beauty that is now truly a beast.
I got to get me some of them leds. :bigsmile:
Now that’s very impressive MRsDNF. WOW!!!
Thanks guys. After my debacle on the driver measurements I needed a bit of picking up. I’ve just completed, or attempted some timed runs. In a 17 degree celsius room with still air the high temp protection kicked in on the driver after 7.5 minutes which flashed momentarily to low and then fired back up to hi. This would happen about every 30 seconds. The heatsink was very hot but could still be held. The driver at this time appeared to be stuck in high when trying to mode change. After cooling down for a few minutes all modes worked fine. I decided to continue the testing in medium. Ceiling bounce output on high was 122 lux at the start and dropped to 53.7 at 7.5 minutes. On medium this dropped to 54 lux. After 30 minutes of running lux had dropped to 52.9 and the heatsink was extremely hot. Again the modes would not change until the driver had cooled of a bit. Hi temp protection did not kick in. I think it may only work on high.
That's quite a bit of tint shift. Do you know what current is getting to the emitter with that driver?
Im not sure what you are seeing/meaning here..
Mose out- 5amp driver. Mouse over 9 amp driver
Its mainly just brighter... Putting out more white light on everything. I don't see anything more special in terms of "tint shift" in the picture above than when comparing say and XM-L at low vs high current.
The 5amp driver looks more green to me, but I bet you're right about the intensity being what I am really seeing. The mouse over really helps.
Comparing the side spill of the light with the 9A driver and the hotspot of the light with the 5A driver gives the opposite effect. Light intensity makes a difference. I think the picture in this post shows that quite nicely.
Sure, there are differences in CRI, tint and temperature at various amps, but those differences are generally fairly small.
