Sorry to hear about the connection issue. Hope your changes give you a nice boost.
I would like to add your light to the MTG2 throw thread. Is the 47334 in Post 12 above the actual lux reading from the meter or is it calculated cd (throw)? I'm guessing its the calculated throw (lux x distance squared) because 47334 lux at 8.6 meters would be 3500kcd.
New pictures added in the first post with the 3C now sporting a IOS 9 amp 3 mode driver. This driver has transformed this light from a light that was did not impress at 120 meters to a light that literally goes look at me now at that distance. To say I’m blown away with the difference would be an understatement.
Thanks RaceR86. I’m running 3 26650 batteries with a spacer. If it works ok I will shorten the battery tube. I haven’t completed any long runs with it yet so I’ll report back when I have. On the light meter it has not increased a tremendous amount but in reality its like the extra current has woken it up. Nothing has made much sense today.
Thanks guys. After my debacle on the driver measurements I needed a bit of picking up. I’ve just completed, or attempted some timed runs. In a 17 degree celsius room with still air the high temp protection kicked in on the driver after 7.5 minutes which flashed momentarily to low and then fired back up to hi. This would happen about every 30 seconds. The heatsink was very hot but could still be held. The driver at this time appeared to be stuck in high when trying to mode change. After cooling down for a few minutes all modes worked fine. I decided to continue the testing in medium. Ceiling bounce output on high was 122 lux at the start and dropped to 53.7 at 7.5 minutes. On medium this dropped to 54 lux. After 30 minutes of running lux had dropped to 52.9 and the heatsink was extremely hot. Again the modes would not change until the driver had cooled of a bit. Hi temp protection did not kick in. I think it may only work on high.
Its mainly just brighter... Putting out more white light on everything. I don't see anything more special in terms of "tint shift" in the picture above than when comparing say and XM-L at low vs high current.
Comparing the side spill of the light with the 9A driver and the hotspot of the light with the 5A driver gives the opposite effect. Light intensity makes a difference. I think the picture in this post shows that quite nicely.
Sure, there are differences in CRI, tint and temperature at various amps, but those differences are generally fairly small.
I wasn't looking at the leaves. I was looking at tree trunks (especially some of the thinner ones) and the driveway. It seemed much more pronounced when I was to scrolling up and down the OP to compare. Now that MRsDNA has mentioned it, I see intensity was definitely throwing me off. I have to admit though, I'm struggling trying to tell how much is intensity and how much is tint shift. I still have amateur eyes. Thank you all for your patience and knowledge sharing.
It was also wet during the first set of pics, that changes colors by a lot.
Ah, thank you Comfy. You hit the nail on the head. I couldn't place my finger on it, because the larger tree trunks didn't seem to look different, but the younger ones mostly did. The pictures make more sense to me know. Nice catch.
