you have answered my question, thanks
i clicked on the flashlight entry and it mentions capacitors being used for energy storage, i’ll start a thread on it
I have wondered the same. Having had at least a half dozen or more lights slightly damaged, or even destroyed by alkaline leaks, I am now freaking out. The few lights I still may run on an alkaline battery, I seem to try and check them every couple weeks. I am now afraid to run an alkaline in any of my decent lights of any kind.
What causes it? The constant high or low temps experienced for example in an automobile? The age of the cell? Multiple cell lights only?
I seem to never have a problem in a TV remote (or smoke detector) for some reason.
The alkaline cell uses the shell — zinc metal — as part of the chemistry. It’s supposed to be thick enough it doesn’t get eaten away from the inside enough to leak — in single use. Ha. Haha. hahahahahhaaha
I’d say it’s poor sealing right from the factory since most never have a problem under the exact same conditions. Capacitors leak too but that might be due to heat/pressure. I dunno, just guessing.
Ahh, do you have a vice or something to wrench it open (you can put leather around it to help prevent scratches)? I used vinegar in my Fluke volt pen as two cells were corroded so much they were stuck inside. It works now after some cleaning and letting it dry out.
That stuff ate pieces of my Stanley 3 in 1 Tripod. All three lights had a crust holding the batteries tight. Fortunately, the metal parts were SS which cleaned up easily with a toothbrush and Liquid Wrench (it’s what I had). I put it back together with the residual oil left behind for good measure.
That’s good. There was a copper strip in my volt pen that needed cleaning with isopropyl alcohol. It really eats through aluminium though. Here’s my ruined Maglite:
I stopped using Alkalines a few years ago. Now it’s just for the few devices where NiMh won’t work, and if I’m worried about someone throwing them away, like the kids. The emergency kits in the vehicles even have LSD or lithium primary batteries in them now.
Most smoke detectors use 9v. They’re a true “battery” of 6 alkalines. Maybe higher standards? A leaky cell wouldn’t show any signs immediately because of the housing which also offers some protection to the device. Our TV remote always gets new cells before old ones start there destruction.
