This will be my most powerful build yet. (12) XM-L2@3A
if the batteries are in series, they will share the load I thought... or you must measure 6 Amps at the last battery.
But if you measure 6A on a parallel setup, all batteries will draw 6A...
or what am I missing
This is correct. A parallel set will give you more capacity (runtime) with same voltage amd current. A series setup will give you more voltage with shared current draw. Thats why when you add more batteries to a series the current drops. I am a noob I could be wrong. This is with my experience only.
Ken
Batteries = 3.7 nominal say 3000mah.
Six in series = 6*3.7v (22.2v) x 3000mah
Six in parallel = 3.7v x 6*3000 (18000mah)
Cheers David
you might be getting confused with the numbers, like when your calculating the input on a taskled driver. more series cells equals less amps into the driver. it’s less amps in only cause the voltage is higher but still the same watts. Sorry if i made it worse.
very nice flashlight but not very good pictures
you don’t have some more pictures with more details of this host?
I like the size of this flashlight but don’t like the number of batteries, 6 batteries are too much for me
Looks like fun. What are you doing for cooling?
Thats exactly what I was concentrating on was the current in. I didn’t even think of the wattage input. I think the closer I am to voltage input vs voltage forward the driver will be less stressed. Also minimal heat up.
Ken
Prestone. Hahaha! :bigsmile: J/K.
As far as the emitters, the head of the light will have to do for now. It does have a lot of nice fins and is solid.
The driver is cooled by forged copper squares with a smaller aluminum square wedged on it too.
Ken
I will get some more pics up this eve.
Contact plate
Driver assembly in front contact plate in back
Switch plate notice where I made the cut.
Switch plate contact side
Switch plate held in with 3 screws
If it is a driver that is a constant led current, more voltage will == less current.
However if the driver is pulling 6 amps at ~23 volts with 6 cells in series, each cell is providing 6 amps.
If each cell was only driving 1 amp, that would also mean 1 Amp at ~23 volts at the driver.
Think of each cells as a water pipe. 6 lined up providing 1 gallon per minute is still only 1 gallon per minute at the end.
6 in parallel doing the same will be dumping 6 gallons per minute at the end.
I got the LEDs today. Thanks to Matt (vesture_of_blood).
I got them lapped and bonded to the base. They are all wired up in series. I tried to keep the wires as short as possible. I will power them up maybe later tonight or tomorrow. I will start at a conservative 2.8A. :bigsmile:
Ken
Thank you! I am by no means a electronic genius. This makes is very clear and simple.
Ken
Wow guys…….
5520 lux at 5 meters.
138kcd
Un-f-n believeable.
Im completely shocked it did that well. The head gets hot real quick. After about 10 seconds I start to get scared. Lol. think I just built a 250.00 dollar 10 second flashlight. What a waste! :~
Ken
When is it too hot to hold?
I havent got it too hot to hold yet. I want to do some temp and battery current tests before I do extended run times.
Ken
Nice Ken. Love your mod. Need some night shots now. :wink:
ERMAHGERD.
My thoughts Exactly!
I'm thinking for a conservative 700 lumens per emitter, you would have 8,400 lumens. More realistic may be 800 lumens, so 9,600 lumens total, but you so need to run it for 30 secs to get a proper reading .
