Shorted data lines is the standard usb way to signal a high current charger, but not everybody is following it.
I have a ihustler stick which is designed for apple products and this has a bunch of resistors in it so I thought apple devices would need a special thing.
That was the reason for adding a switch, but the housing is so small even with grinding the switch didn’t fit perfectly and the tests with open housing showed me that the shorted wires are always better for my devices.
Shorted wires have a second benefit you don’t need to mind where you charge your device, I always have a bad feeling on public chargers…
Apple is using another ways to signal current on their own chargers, but they must also have added support for the usb standard in some product.
Are you concerned about security or something else?
Yes, however that price includes one of their Fast-Charge 3-in-1 Cables that enable faster charging of devices, including Apple devices plugged into non Apple USB ports.
I also appreciate them developing a legitimate business selling a well designed/made product versus a cheap and flimsy clone. FWIW, I did buy one of the cheap devices to get the current/voltage readings. Fine for initial testing of chargers and USB ports at home. Once I know their characteristics, I can use the Fast-Charge 3-in-1 Cable to take full advantage of them, at least that is my plan.
Does the cable work, does it enable faster charging?
I can’t say until I receive the cable.
What I read here convinced me to buy the cable: http://www.kickstarter.com/projects/david-toledo/the-practical-meter-know-your-power
This is a link for the cable itself: Situs Judi Bola Resmi, taruhan Mix parlay terpercaya - INDOBET365
I hope this helps.
First rule of measuring stuff, everything matters. I would make a test rig, a dummy load on one end of a USB connection and voltage test points on both ends and do some testing.
With a 1A different I suspect you are correct and its not switching to high current mode. Stock I think USB is only good for 500 ma. but some do more.
Agree, cute device, not much of a measurement tool.
Works very good as a measuring tool that it is. I used it to weed out cables used on the same charger that gave me very long charge times and now I can see why. Same charger different cables gave me from 400mA up to 1,700mA so I sorted out my cables using this Tool and my charger works faster now; I got my measurement tools from DX, can’t be beat for the price.
Good for that task, sorting cables, but not for actually measuring values since its insertion in the circuit changes the current too much.
Been waiting 33 days for mine, contacted the seller yesterday, he said wait a bit longer , I’ll be claiming when it gets to 40 days.
Claimed a refund from the ebay dealer, it never did arrive.
You are really expecting too much from a 2-3 USD device. :zipper_mouth_face:
Not really, I have no expectation regards price these days, you just never can tell. Its a useful device, but only to compare A vs B, or to see if a device is working or not.
I have opened the Case to investigate why the shunt resistor is hanging around a bit angled and it seems to be something small red underneath, maybe to give some distance to the PCB or so? Over the display there was a protection foil which I removed, not sure if this make reflections worse?
I will play with that next week as I want to add a switch to shortcut the data lines for high current charging of phone and tablet with any USB source…
Really?? on a gadget this cheap? I doubt the Seller would know why somebody in a Chinese sweat shop was lazy :bigsmile:
That was the reason for adding a switch, but the housing is so small even with grinding the switch didn’t fit perfectly and the tests with open housing showed me that the shorted wires are always better for my devices.Shorted wires have a second benefit you don’t need to mind where you charge your device, I always have a bad feeling on public chargers…
How does a public charger work? We don’t have any public chargers here in the USA that I’m aware of, you must bring your own when you go somewhere……do they charge by the hour to use a public charger or are they totally free to charge-up your device?
Mine took 25 days to arrive. For the money it's pretty nice. It's missing a few surface mount devices compared to the other photos posted in this thread. I tried to pry my case apart but it seems to be glued so I'm not going to wreck it in order to post a clear picture. Here's what mine looks like with the case on..
Did that one come from DX?
I meant that there is always the possibility that something gets transferred over the datalines if you plug your phone in. It was/is called Juice hacking…
No, it came from this ebay seller
The ones I got from DX are the same.
I wonder how many different circuit versions there are?
Look in airports, very common to see a kiosk with a couple dozen types of connectors sprouting out with some brand advertisement. Carry on luggage can be such a fuss many will pack the charger in checked luggage or not bother on shorter trips. 10 min hanging around the kiosk can put maybe 2/3 of a full charge on a lot of phones.
