I'm in for 3 as per PM - Paypal sent in a minute. I was going to ask about the voltage too because I'd only heard of over 3000mAh cells that needed to be charged to 4.35V. This is much better. I may just have to build something that pulls around 6A for proper testing.
Or something. With 6A to play with, a LOT of light ought to be available.
Ok, great! I'll be very interested to see how well the PCM handles 6A continuous discharge, it is specified as 4-6A continuous, with 8-12A excess current threshold.
I've added a picture of the Panasonic data-sheet to the first post by the way.
EDIT: Please bear with me on the PCM cut-off tests, I've run it for the last hour at 0.5 dropping to 0.3A on the med mode of the manafont drop-in and it's only dropped from 3.49v to 3.28v, so it could be a while before it hits 2.8v..
..3.09v and 0.23A now almost half an hour later. The problem with the manafont drop-in is that it's completely unregulated, just using PWM percentages to create a dimming effect, so it will just dwindle and dwindle. I'll try and keep it going until it cuts out though.
I would use one of my DIY drop-ins but they all use NANJG drivers which have their own built in overdischarge protection (at 3v I think) so that wouldn't work. I'll try it in my T100C2 if this doesn't work out, that has a low 0.15A mode.
Unfortunately, the manafont drop-in drops out of any sort of regulation as the cell gets to 2.8v, pulling less than 0.05A on med and 0.01A on low, and by the time it has reached 2.6v, current is down to 0.03 on high, 0.01 on med and unregisterable on my DMM on low, so I believe it has bypassed the circuit. There is no risk of failing to notice the output dimming in a direct drive light like this however, especially at such extremely low voltages, so it shouldn't be much of an issue with this cell for which 2.6v is still safe. I'm running down to almost 2.5v though to be sure, then I will try it in my T100C2 which has some regulation, I think under a regulated load it should cut-off more quickly.
In testing dozen of cells with protection circuits, I've never seen a single one kick in at recommended cut-off voltage (typically 2.8v). I think I'm going to test a few cells to see how low you need to go.
There may be issue with the protection circuit cutting in, as many 3-4.2v divers have inbuilt protection
So what happens is the driver switches to protected mode @ 3v and you get something like moon mode or less .
If you want to trip the protection , you should consider a buck boost driver equipped light, so when the voltage drops the driver begins to boost and really begins to drain the battery .. This should trip the protection circuit without fail .
But this will be under load , and the voltage will begin to bounce back almost straight away , once the load is removed .
Yes, that is what I was thinking. But I would like to test if these cells do eventually cut-off at a safe point, otherwise I will have to remove my claim about running them until the PCM cuts in, which would be a shame.
The current has seriously dropped off in my T100C2 as well, it is at 0.06a now at 2.9v, I think I will go down to just below 2.5v this time to be sure. I really hate doing this to these cells though, I set aside two to keep for myself and now I am running one to within an inch of it's life.. It should be able to take it though, Panasonic say it can anyway.
Ok, I've had to call off the second test now as well, the light did go into a 'moon mode' type setting, and I gave up with the cell at 2.84v. I will try again as soon as possible but have to go test my new bike light out now before it's too late. I am going away tomorrow until Thursday afternoon so please don't worry if you can't get in contact with me until then.
I've yet to find a protection circuit that actually cut off on low voltage at low current drains. All of the ones I've seen thus far depended on boost drivers that would jack up the current to silly levels as the voltage dropped. If there is one out there that actually cuts off on voltage rather than current (for a price measured in pennies, not pounds), I'd get 100 of them tomorrow.
I have now edited the OP to reflect the possibility of bypassing the PCM at low currents, please bear this in mind when purchasing any protected li-ion cells. That said, with this being an almost universal behaviour of li-ion cell PCM circuits these cells which can be discharged to a lower 2.5v than traditional li-ion cells should offer safer performance still. As by the time they are discharged that low, and in fact even significantly before that, current will have dropped to very low levels and it will be obvious the cell needs recharging soon.
In any circuit where current won't drop obviously at such low voltages, the PCM should trip successfully, doing it's job of protecting the cell.
Im looking forward to your review Don. Thanks for taking them on for the team.
As far as I am aware (and after reading all the comprehensive battery reviews at the other place) there isnt a PCM fitted to any 18650 that will reliably disconnect power once a target voltage is reached unless combined with a substantial current draw on the battery to trip the circuit. Only one of my cheap 18650 lights (that I am aware of) is equipped with a constant current regulator (light does not dim as the cells become depleted. Amperage draw increases as voltage decreases). My early example TR-1200 with 3 x 18650's will trip the PCM once voltage drops to around 3.6V while under a heavy load. The rest of my cheap lights simply dim, and if left on, will kill a battery all the way down to 0.0V. On my examples I have noted that the heavier a CC draw is on the battery, the higher the cutoff voltage becomes.
Lets hope for cool running, mega low resistance, higher capacity numbers @ 3A than the other offerings.
I don’t mean to nitpick, but that’s constant power, not constant current. Constant current would be just that… one current the entire time (like the battery discharge graphs above)
Only 9 left now until the next order, I'm off to the post office today to ship the first 3 sales. I'll not be back until tomorrow afternoon, (I am doing more than just going to the post office) so please don't worry if I don't reply to PMs right away.
You could get six protected trustfire flame 2400mah cells (with free shipping) for the price of one of these 3100mah cells and shipping.... Sorry, just not worth it, for me at least. It's not budget-light compatible with those prices, either...
Can you? £9.99 + £2 = £11.99. Trustfire flames are £6 for two at DX, so you could get 4 surely? Believe me I have gone down that route before, the Trustfires are great cells for the money, they do pretty decent in low draw applications and some can even hold up to 2.5A. But the consistency and reliability just isn't there. I have had about 10 of them, and while 7 work fine, 3 of them have over time developed problems, and either can't sustain high currents (high resistance) or flicker on lower levels, or don't hold a voltage.
With li-ion cells I like to know exactly what I'm getting and be able to trust my cells to perform well and consistently for a long time. So I started moving further over to buying AW and Redliast cells, then I realised I could bring a higher capacity and equally high quality product to the market for less money. I know I will get comments about the price having listed on a forum dedicated to 'budget' options, they sure aren't 'budget' cells. But for their quality, they are actually priced noticably less than the competition.
Seems to be a few " based on the Panasonic 3100 cell" Li-on batteries popping up on the forums. I wonder what is happening that they are suddenly being marketed like they are the Ferraris of the battery world?
I see that the actual Panasonic 3100 is advertised for $6.55 per cell, why are the copies more expensive?
I went by US$, being as that's where I am - six at $8.38/pair is $25.14 with free shipping, while one of these is $22.99 including shipping... so I exaggerated slightly - you can only get five and a half protected trustfire flames for the same price, not six. So far I've had no problems with the trustfires, and with that price difference, I can throw four of them out and still have more mAh/$.
I've had problems with other brands, although I could get 14 of the ebay ultrafire 3000mah counterfeits for the same price as one of these....
And spending three times as much on a battery as the light I'd be putting in it seems just plain wrong. Even after the xm-l and new driver I plan on putting in several of my lights, these cells still cost slightly more than the lights and upgrade parts...
Find a way to sell them for under $10/cell including shipping (that's still over twice what the trustfires cost), and I'll consider testing one or two.
While ~$20 does seem a bit high, it's not exactly outrageous. The price above for loose unprotected cells is for minimum 100 and the going rate for standard sanyo's on ebay is $10/apiece. Just because kinda crappy cells are $5 apiece doesn't mean someone who wants to try the latest and greatest is overspending when it's only $20 anyway.
