bgyen
(bgyen)
September 27, 2013, 3:10pm
118
Banggood has an UltraFire WF-501B for $6.79USD with coupon ‘bgaclf’ it’s $5.77USD
UltraFire WF-501B G74 Flashlight
Features:
Material: High quality 6061T Aluminium
Crenellated strike bezel for enhanced self-defense
Also designed to mount on certain hand pistols, rifles and shotguns with proper mounting equipment
Bulb: Xenon 3.7V/1.2A 900 LUMEN
SuperBright, blinding Effect
Lifetime-above 10,000hrs
Working Current: 1.5A
Operate Voltage: 3.7V
Power supply: 1 x 18650 battery(Not Included)
Runtime: 1.5-4.8 hours depend on battery capacity (continue working)
Body Color: Black
Switch: Tail cap Clicks On/Off
Waterproof, It’s water-resistant ! use it in rainy day, no problem !
Package Includes:
1 x UltraFire WF-501B led flashlight
Sirius9
(Sirius9)
September 27, 2013, 3:25pm
119
not an expert for xenon bulbs but this doesn’t look like xenon to me (I would say it’s XR-E Q5)!!!
Pulsar13
(Pulsar13)
September 27, 2013, 9:25pm
120
10pcs generic 12V 10W emitter (2 days sale) for $7.33 shipped (for white/WW):
http://www.aliexpress.com/item/FREE-SHIPPING-10PCS-LOT-10W-900-1000LM-LED-Bulb-IC-SMD-Lamp-Light-Daylight-white-High/835706576.html
This was reviewed here:
Ok, here goes; my first showdown. I’d like to try to post one of these once in a while, mostly for fun, maybe as part of a giveaway.
This was not a scientific test, for sure. My integrating sphere is not even close to calibrated, but it can give me relative output results; good enough for a showdown.
So here goes…
[image]
On the left is a generic 10W LED module in a WW tint (~3000K). It’s arranged in 3s3p, for a total of nine 1.1W emitters.
In the middle we have the ol’ standby, the trusty …
I know it’s not the most efficient nor the best emitter, but at 73cents each, it’s a really good value. Cheap and functions from 12V direct with just a 1 - 2ohm resistor in series.
Nightbird95
(Nightbird95)
September 29, 2013, 2:45am
121
ohaya
(ohaya)
September 30, 2013, 4:02am
122
Hopefully this is a new deal (from Banggood):
GM300 Digital Laser Point Infrared Thermometer Temperature Meter Gun - $10.99
Description :
GM300 Noncontact Digital LCD Laser Point IR Infrared Thermometer Temperature Meter Gun
Brand new & high quality.
Lightweight and compact.
20 seconds auto power off.
Simple One-Handed operation.
Celsius and Fahrenheit switchable.
Laser sight allows accurate targeting.
Simply point to an object and read its temperature.
Precise non-contact IR thermometer, safe and easy to use.
Laser on/off switch, Auto power off & temperature data hold.
Consist of optics, temperature sensor, signal amplifier, processing circuit and LCD display.
Suitable for: hot water pipes, hot engine parts, cooking surfaces, hot tubes insulation, electrical connection, ballasts in electric lights, electric motors, bearings, wine coolers hot asphalt, swimming pools, fish tanks, hot & cold food products, heating air conditioning, etc.
Specifications :
Weight : 132g
Emissivity : 0.95 preset
Resolution : 0.1℃ or 0.1F
Spectral response : 8-14 um
Distance to spot size : 12 : 1
Accuracy : ±1.5% or ±1.5℃
Temperature range : –50 to 380℃
Repeatability : 1% of reading or 1℃
Operating humidity: 10 ~ 95 % R.H.
Response time : 500mSec, 95% response
Dimensions : Approx. 155 * 100 * 45mm
Operating temperature : 0 ~ 40℃ (32 ~ 104F)
Storage temperature : –20 ~ 60℃ (–4 ~ 140F)
Power supply : 9V Alkaline or NiCd Battery (not included)
Package Included :
1 × Infrared Thermometer (Battery not included)
1 × User Manual
Detailed pictures :
!http://imgmgr.banggood.com/images/upload/2012/jiangjunchao/SKU0880872/SKU088087%20(1).jpg !
EDIT: Another BLF’er pointed out that there seems to be the same one on Ebay AU:
http://www.ebay.com.au/itm/Gun-Thermometer-Digital-Temperature-Meter-Tester-Non-Contact-IR-Infrared-Laser-/170998929683?pt=AU_Decor_Furnishing&hash=item27d0549913&\_uhb=1
AU $9.19
Sorry about that!
Jim
ohaya
(ohaya)
September 30, 2013, 3:50am
123
Instant kill (I think), about 1 1/2 days from now:
and VIP kill (6 days + from now):
sorotantaz
(sorotantaz)
October 3, 2013, 3:12pm
125
Skyray SR5 with XML discounted at $9.99.
I own two of these similar hosts from other seller. not 100% sure it is the exact same host design. the bezel looks bit different.
even so, this is most catching P60 host in my eye.
edit to question below: well, my two are P60 host. since the one on the link has a little bit different look, I’m not so sure the entire inner design is the same as mine. but I’m quite sure it still a P60 host.
Alcius
(Alcius)
October 5, 2013, 11:23am
126
Sirius9
(Sirius9)
October 8, 2013, 12:26am
127
Not sure if deal but banggood now has Olight i2 EOS with very good price (don’t forget to use blf discount code)
Only confusing part is that title and description says it is a XP-G2 R5 while pictures clearly show old XP-G R5!!!
bikenber73
(bikenber73)
October 8, 2013, 3:48pm
128
jmpaul320
(jmpaul320)
October 8, 2013, 4:09pm
129
nitecore tiny monster tm11 cool white for 99.99 from illumination supply
https://illuminationsupply.com/tiny-monster-tm-c-28_53_75/nitecore-tm11-2000-lumen-cool-white-4-x-18650-8-x-cr123a-p-749.html#.UlNvlxD3O8A
CODE is weeklydeal
ongoing thread here if you want to send directly to vinh to mod
Ouchyfoot
(Ouchyfoot)
October 8, 2013, 5:10pm
130
Sirius9
(Sirius9)
October 8, 2013, 11:00pm
131
southland
(southland)
October 14, 2013, 12:17pm
133
BatteryJunction.com has 25% off select Jetbeam lights with coupon code “jumbo” here.
You will have to pay shipping so that negates some of the savings. For me the shipping cost for a Jet III M was $7.50, didn’t buy it just added to cart to check shipping. Could be a good deal if you are buying one of the more expensive lights like the DDR30 or if you buy multiple lights.
NickBose
(NickBose)
October 14, 2013, 1:11pm
134
Sirius9
(Sirius9)
October 15, 2013, 7:00am
135
Rofis Group buy w/free fenix E01 here.
_the
(_the_)
October 15, 2013, 6:15am
137
