BTU Shocker Triple MT-G2 with a twist -- Aiming for >100Watt ~9000Lumens -- With external 2S power pack, handle etc...
What I really meant was placing to unprotected packs in series is quite iffy to us battery snobs. :)
Nice modelling work, btw!
I'm sure it's possible, if the spacer is designed correctly, for your BTU to still function as a 18650 flashlight. :)
Thinking about it, though the tube in standard form will not take a 4 cell carrier if you had machining facilities it could be made to do so.
The end cap from a FF4 fits the Shocker In fact the shocker’s battery tube is slightly bigger in diameter, so I would think that even after machining there should be enough metal left for reliability as there is in the FF4.
If the socket, plug and lead does balance the head that will be a bonus.
If you go down the active cooling path be interesting to see which way you go. I have been looking at a sandwich peltier and annular fan for one of my projects (a 47 yo space beam torch updated slightly LOL).
Yeah I wish I had the tools and the ability to machine, would make things a lot easier alright.
Another question for the BTU owners. If you thread the tail cap as far as it will go onto the head of the light i.e eliminating the battery tube entirely. How much of a gap is left to fill between the head and the front of the tailcap?
Assuming you can’t screw the cap on all the way because of that long threaded section on the head.
Peltier coolers are definitely fascinating. Maybe I can figure out some way of making one work here.
Cheers
I’m using an XLR plug in conjunction with a 13.1V LiPolymer pack to power an older Canon 1DsMkII camera that had a NiMH pack. The OEM pack is unreliable with some age on it, my external pack will run the camera for several days.
Of course, I’m not pulling the amps you’re looking at, but I’ve no issues with the plug whatsoever.
Nice work, love the renditions, can’t wait to see what you actually do. One of those would be fantastic in the Photography profession, on location lighting extraordinaire!!! :slight_smile:
I’m just wondering… why use BTU? it is very heavy…
why not use Fenix TK75 instead? as it have a deep reflector too and can add more battery extender for longer runtime or more “juice” :smiley:
Well two reasons mainly.
1. I was offered the BTU host without leds/drivers for a very good price. So that’s what started this whole mess :slight_smile:
2. I don’t have a Fenix TK75. Are you offering me yours? hehe :party:
But yeah, I know it’s probably not the ultimate choice for what should be a relatively light host+heavy battery pack combination but then again the extra mass has heatsinking benefits as well.
Looking at the Fenix, I love the extra cooling fin surface area, the BTU is sadly a bit lacking in that department.
Linus
Yes I think a good XLR will do fine even at those higher currents. In fact I know mine will work fine since I tested my power pack cable and connector combination last night.
At a constant 15A and 20A the connectors didn’t even get warm, and even if they did heat up a bit the plastic construction on the inside seating the connector pins is made of something I can’t melt with a 450°C soldering iron.
The 18awg cable however will make a nice hand warmer. It got up to 50°C after 4mins at 15A, with a drop of 0.68v across the cable when cold, up to 0.74v at the 4 minute mark.
Was hoping for better.
Massive waste of energy right there, really need to find a more suitable cable, at this rate it might actually be more effecient to boost the voltage from the battery pack to something like 30v and then convert it back down to 7.4v in the torch. haha.
Having said that you have to be careful you get a decent XLR for power, I think mine must have been designed for speaker use or something else that matches or exceeds their 15A max rating. With plugs that aren’t universally used for high power distribution the construction can vary quite a bit. I have another XLR plug that has very thin contact tabs inside not really designed for soldering wires to. And the plastic is not as heat resistant either, wouldn’t be comfortable using that one here.
I can certainly think of a few uses for this light when it’s done :slight_smile:
If only! How I envy those that have a workshop these days :cowboy_hat_face:
The tail cap does not screw into the thread on the head (poetry :nerd_face: ) it is bigger! :frowning:
Oh, you see I wouldn’t have guessed that from the photos I’ve seen. Good to know, so it will require some machining to make this work. Thanks for the heads up!
Note to self: Always have flashlight host in hand before planning mod! :wink:
The cap is not that much bigger so it is a pain… hopefully it may be possible to get a cap from another light that would fit.
I do know a machinist who lives locally so getting something modified or a thread cut isn’t entirely out of the question, certainly finding parts that fit from other flashlights is an option but often I’ve struggled to find spares sold separately and buying a couple different flashlights just to use a part or two from them doesn’t feel right.
Not to mention that would leave me with another orphaned host that’ll require modding…vicious circle that! :slight_smile:
Getting a new end cap to exactly your design would be the way to go! but I hope the price would not be too high as you know the bloke. I want a double length battery tube for my shocker, but the quote I got was stupid money.
Must admit the few times I have needed parts for modding lights, I have been lucky to have found suitable donors from jumbles/charity shops and boot sales. So never felt that guilty about nicking bits off them.
Never quite understood the reluctance of light manufactures in selling spare parts.
Yeah, it’s a shame. I had no luck at all in finding spare parts for my Apex 5t6 and there’s quite a lot of those models out there. Even contacted a number of resellers to see if they had returned or broken parts/spares that I could buy. No deal. I suspect there’s just no incentive to make extra parts for customer service type situations and even factory seconds end up being used in making up a batch of second rate flashlights of varying quality that go out on sale.
For the BTU, at the moment i’m thinking more along the lines of shortening the front of the battey tube and machining a new thread inside so it can thread onto the head. Getting the spacing of the tailcap to the body just right once it’s fully seated into the head. Something like my last rendering, I quite like that form factor and it would still give me some limited space inside the body for whatever.
I dunno, I’ll have to put a lot of this aside until I have a play with the host and see what would make the most sense.
You should apply this for fenix flashlight design!
I didn’t know about the fenix competition, thanks.
Ok so I have a bit of progress to report, today I made the trigger clicky and it’s enclosure/mounting.
I haven’t cut the enclosure to the final assembly size/shape but the masking tape shows what the final thing will look like.
Way too risky to cut this now based on estimated measurements!
Inside it’s simply one of those standard 1.5A omten reverse clickies mounted on some random tailcap pcb I had lying around and trimmed down to fit inside the enclosure.
The enclosure I made from a 5v transformer/power supply casing which had a nice little ergonomic lip at the base. I cut this in half and sanded the two halves until I had the width that I needed. Then glued the two parts together, drilled and dremmeled out the hole for the switch boot and put it all together. There’s a backing plate mounted into a grooves inside the case and plenty of hotglue to ensure the switch doesn’t go anywhere.
The cable will run down inside the handle through the middle dovetail groove and the twisty part will take the rest of the cable down to the tailcap. Not certain how I’m going to run this into the tailcap just yet but probably just through it’s own port. Maybe with another connector if I get real fancy, for modularity and flexibility. :stuck_out_tongue:
Also just to be clear I won’t be running 15amps through this cable! It will just be the control switch for the drivers.:slight_smile:
And finally here’s some more renders of the model with the switch mounted. The blue line shows where the cable will be running.
Those MT-G2s are to scale btw! Huge buggers!! :party:
Cheers
Linus
Bit more planning stuff, this time on how I will be tackling the emitter mounting and how I’ll approach sinking some heat into that massive reflector.
Front view showing the noctigons in place and the crazy pattern of necessity for my copper spacers :).
The idea is to have the reflector back sitting flush on these copper spacers and sucking some heat off the pill.
Would love to be able to machine a nice copper spacer/gasket for this but I’ll have to make do with what I can find.
So far I’ve found some 15x15mm copper squares on ebay available in various thickness so I’ve ordered a bunch of different packs to combine and hopefully cover my spacing needs.
Going by my measurements and Noctigon/Cree datasheets I should need a spacer height of 2.3mm to just clear the top of the MT-G2 baseplates with the reflector. (The emitters pcbs themselves will probably be glued down)
So I’ve ordered 2mm, 1mm, 0.3mm and 2x 1.2mm sets of 10 spacers so I should be able to cover any distance that’s 2mm, 2.2mm —> 2.5mm in 0.1mm increments and even reach to 2.7mm if get some crazy tall noctigons for some reason. :stuck_out_tongue:
Of course they’re all separate little squares so once I’m happy with the fit I’ll probably try reflowing them together. Maybe in a kind of press or something that can be heated while keeping the components under good pressure to get a nice tight single piece copper disk. This sounds like a nightmare by I’ll give it a go :slight_smile:
In the end I just hope to be able to sink some heat into the massive bulk of the BTU reflector, because in stock form it looks like there is very little thermal pathway between it and the body/pill.
For the emitter wiring I’ll need to drill 6 holes through the pill surface to get the wires close enough to each pcb solder point. I figure drilling at an angle from the places shown on my model I should just about be able to drill through the thinner part of the pill and gain access to the driver cavity without going through too much solid sidewall.
In there I’ll have to see about adding some more thermal mass that’ll bolt to the bottom of the mcpcb mounting plate.
Depends on how much space I need for drivers and such.
For the drivers I’ll be running a separate set of 7135s/(slave driver) to each emitter so while the whole circuit will still be in parallel I should gain some per emitter regulation and avoid any issues with differing vF or resistances.
So that’s it, let me know what you guys think and if anyone has attempted something similar that I can learn from.
Especially with regard to those copper spacers and reflowing stuff like that together.
Cheers
Still here reading. Interesting.
Wow! I was thinking of getting a copper screw to replace the standard screw that goes into the reflector, thinking it will heat sink from the pill top to the reflector. Getting direct contact from the pill top to the reflector is a little beyond my capabilities, but I gave it some thought, wondering if even thermal pads stuck in there and compressed on contact would help, but don't think they are very efficient.
Still not sure how you will get the "perfect" spacing from those copper inserts to the reflector - you want the reflector sitting down to get the best output of the emitters for sure, not to mention how perfectly level they must be. Maybe you will use some quality thermal paste in there?
yup it may all go horribly wrong! :wink:
The biggest problem will be getting those copper pieces together and perfectly flat for sure. I imagine there will be a lot of cutting, sanding and cursing at whoever stenciled out the pieces in the first place.
If I get it just right the reflector will be fully seated on the spacers and the emitter domes will be as far into the reflectors as possible without themselves actually being pressed down on by the reflector rim. I want the pressure, if any to be on the solder points on the pcb. If I then find I need to move the reflector out a bit more because the focus of the emitters is wrong I should have the ability to do that by changing around or adding on some more of those copper spacers.
And yes there will definitely be a generous amount of thermal paste on all the contact surfaces. :slight_smile:
With regard to the copper screw, that’s a really good idea. I need to look at that, maybe I can find a high-copper brass bolt to replace the one that’s in there. Can’t hurt :slight_smile:
You wouldn’t happen to know the thread size and length of the stock bolt would you?
Cheers
Crap! Actually I worked on a Shocker mod'ed by someone else and they left the screw out! I found one that fit well, but think it was a US size. All I had to do was cut it down. Hhmm, can't recall the thread size... Was thinking of brass too, but like you said, high copper content would be better I assume.
Running these Shockers at 6A to each emitter does get warm pretty quick, so would think getting that reflector to do more heat sinking is good, but your amps have to be up there, because 4A is no problem with the pill and pill area.
