You guys are vewwwy close. But this is an exact game. So I need to see who nails this exactly (should’ve mentioned that specific brands must be stated) before I go on to the next lego!
MRsDNF, threads are close. Other than where you see the o-ring showing due to the quantity of female to male thread differences this ensemble still screws together like it was meant to from the factory. IOW there is plenty enough thread engagement that this light is entirely potentially functional. Just needs a switch and driver. “Just”. :bigsmile:
I’ve been thinking about how to rig up a side switch with this setup. Or maybe a rear clicky. Much less a driver. I believe it can be done.
Just so you know, the OAL is only a tidge under 6 1/2”. Talk about what could be one mean mammajamma pocket rocket!
Definitely looks like a polished DST head …and the base definitely looks a gold SRK body… >>> just like this all black one i have right here… :bigsmile:
DenBarrett certainly shows the proof and then some. It’s a FandyFire UV-S5 (SRK clone) mated to a polished Defiant Super Thrower (DST) head. Remove that o-ring and it looks like it could be almost factory.
Now who’s capable of making this thing sing? I mean you know, there’s only 4 x 18650’s in that tube. :bigsmile:
This is a little tuffer. It will run off a 26500 if you bore out the tail cap and side clicky housing a bit otherwise a 18500 with a sleeve goes in without boring. OAL is coincidentally to the Fandy/DST is also just
6 1/2”.
Feels really great in the hands which IMO is helped by the side clicky. Everyone that picks this up goes, Ooooooooooooh!!!
Yup, he nailed it. Almost. It’s a 5C. So all ya gotta do is somehow find a 5C Defiant that can actually be taken apart from the tube and then just thread the tail cap to the side clicky part which threads perfectly. And voila! You now have a compact little blaster. Especially de-domed. :bigsmile:
Most of the 5C Defiants btw are stuck together with nitro glue.
I had an unfair advantage. You recommended that combo here. I remember because I purchased the SG-R13 on that recommendation. I have not performed the recombination yet though.
