I’m already been working on somthing if a variant of this.
( more info soon.
I knew I recognized those cut outs on the handle there. That fandy is on my ‘buy when I win the lottery’ list.
This is a little tuffer. It will run off a 26500 if you bore out the tail cap and side clicky housing a bit otherwise a 18500 with a sleeve goes in without boring. OAL is coincidentally to the Fandy/DST is also just
6 1/2”.
Feels really great in the hands which IMO is helped by the side clicky. Everyone that picks this up goes, Ooooooooooooh!!!
Looks like a shortened version of the standard 3C Defiant light. ( probally using a single 26650, 18650, etc. ?
Yup, he nailed it. Almost. It’s a 5C. So all ya gotta do is somehow find a 5C Defiant that can actually be taken apart from the tube and then just thread the tail cap to the side clicky part which threads perfectly. And voila! You now have a compact little blaster. Especially de-domed. :bigsmile:
Most of the 5C Defiants btw are stuck together with nitro glue.
Interesting i have one and never thought about trying that. What cell are you using ?
nice
Any guesses at this one ?
Sipik 98 head mated to, to, to…….
You have one part right of the two.
The Defiant AA!
I have done the same. Sweet setup.
EDIT: Ooops I spoke too soon, although that works too
This could be a tuffy. Well maybe not for Lego-King DenBarrett.
I should be disqualified from guessing, but I will anyway. Ultrafire SG-R13 tail and one of the many decent C8 heads available on the market.
You guys are good.
I had an unfair advantage. You recommended that combo here. I remember because I purchased the SG-R13 on that recommendation. I have not performed the recombination yet though.
but what the hey a darn good calculated ‘guess’ is better than pulling it outta somewhere dark! I think you’ll like the setup.
This one should tweak a few frontal lobes. hehehe
Then again I’m dealing with some pros here.
Is that one of the solarforce L2 heads?
Tuffy is as tuffy does. :bigsmile:
