Homemade P-60 Drop-in XML 1A vs 1D
I started making my own p60 drop ins for fun. I really liked the cool white 1A tint for brightness at first at 2.8 amps these are as bright as the Manafont direct drive drop ins, but now I am totally infatuated with the 1D tint.
I use these P60 empty drop ins
http://kaidomain.com/ProductDetails.aspx?ProductId=11201
I use the Nanjg 105c 2.8 amp drivers.
http://kaidomain.com/ProductDetails.aspx?ProductId=11088
I use these isolation discs.
http://kaidomain.com/ProductDetails.aspx?ProductId=1745
I was using these cool white XML 1A on 16mm stars.
http://kaidomain.com/ProductDetails.aspx?ProductId=11130
I use these Shiningbeam XML premium tint 1D on 16mm stars.
http://www.shiningbeam.com/servlet/the-34/**NEW**-Cree-XM-dsh-L-T6/Detail
Here is some parts fresh out of the envelope.
Drivers are soldered, 3 mode selected and ready, going to prefit everything before I solder the emitter and driver in and glue it down with Fujik on both sides driver and emitter.
Driver is glued and soldered in, looks good.
Emitter is glued in and the isolation disc is stuck on top to prevent shorts to the reflector.
Used an OP reflector, it is good to go now to find a host to test it in.
Host 504B XML 1D on left XML 1A on right low mode.
1D on left 1A on right medium mode
1D on left and 1A on right high mode.
I am really liking the 1D tint. The camera really captures a very accurate tint color. Now what do I do with all the 1A tint drop ins I made? What do you guys think about these 1D tint emitters?
Awesome .
I think I like that 1D tint a lot. I'd still be willing to receive all the 1A emitters you no longer want. :D
Oh, wow, 1D look awesome. The world has too many 1A's anyway. You should sell some to your friends on BLF. :D
1D tint looks really good! Do you think i could use teflon disk as isolation disk?
1D is nice, I like the 1A tint when they come with a little red in the beam, both of my manafont drop-ins came like that. By far my favourite though is the 3C neutral tint which you can get in T5 flux bin from illuminationsupply, they're only $9 each as well. So not more expensive than these cool tinted ones.
EDIT: Sorry, I just checked and it appears they're sold out. It may be worth contacting them to ask when they'll be getting more in stock though.
You can use anything that is not conductive and fits between the reflector and the pill, I usually squirt a little Fujik on the solder points before I stick the isolation disc on for added piece of mind.
RF UK I have a T5 3C but it's on a 21mm star, so it won't fit on a P-60 pill. I was hoping to use it on the Tmart C8 deal that went bad, maybe I will take my C2 apart and try it on that.
If you wanna get rid of the 1A's I'll take 'em!! I don't like the 1D.
Serious!
Rich
I love the 1D, esp when doing inspection work. Better color rendering
Hey nice post. I didn't know making your own drop-in was so simple.
I can see it now: "the BLF build-a-P60 dropin" at your local mall.
We can sell thousand of it and with money we can create the BLF flashlight Factory, where your dream come true!
Building a drop-in is not so difficult. The real problem is to find the right reflector for the emitter you want to use. For Q5, Q3, etc is quite simple but for some other emitter (R5) is really difficult.
You are so right about the reflectors, but really why would you build an R5 when for $2 dollars more you can have an XML that does everything better. I have even converted R5 lights to XML and they are noticeably brighter.
[quote=Davx]
Have you tried this one? Very goood reflector for XP-G/E emitters.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=9208
Great advice!
How can i miss it? Already ordered a couple! Thanks Hrvoje!
Hmm. .. Are you sure that's 1D? I just looked at the cree chart and 1D is right adjacent to 1A with 6000k-6500k. From the photo it looks closer to 5000k. Not quite neutral, but not WC either. Man, if you could get Neutral stars... sell out within minutes.
How can I be 100% sure, I don't have a spectrophotometer so there is no way for me to tell the exact tint. I trust Shiningbeam sent me what I ordered and they definitely look very different from the 1As I have, but how do I know those are really 1A. I am positive I like the tint the best out of all the different tint emitters I have and that is what is important to me. Eventually I will find some neutrals on 16mm stars the ones I have now are on 21mm stars so I can't do much with them.
ooooooh. must... not... buy... more... lights....
(this month)
Nice work though!
I was able to find ONE "3s" bin on a 16mm star... last they had. I should have it in a couple weeks. Ebay seller JTS Galaxy has them on 20mm stars, but no 16mm boards. Everyone seems sold out of them...
--Bushytails
Actually by carefully shopping around it can be made for 16usd tops! Not trying to imply your work isn't of value. :) It is usually underappreciated and people think you're having way too much fun with that making one for free seems just right. :/ Charging 7-10usd to make one seems pretty reasonable to me.
2,20-3usd reflector/pill assembly (buying bulk)
4usd driver (buying bulk)
7usd XM-L 1A led (LCK-LED)
some thermal glue and isolation disc (less than 1usd for both, providing you already have them)
Solder.
Takes me 10min after the iron is well warmed up to make one providing you like the wires KD ships along the drivers. However it takes 10h for the fujik glue to cure properly.
Additionally 1 20mm oring cut to suit the pill size (above the emitter star) if you like to have a spacer between the reflector and the soldered conacts on star and also fine tune the reflector to star distance not to mention having it sit prefectly aligned which without isn't often the case. Slight tilting may occur.
Oh and btw, i found putting the isolation disc on the reflector instead of the star works best for me.
Budget-bender dropins vs. Budgeteer-bender dropins! who will win?
Specs: same
Parts: same
Quality: ... need a sample from both of you to test ...
Price: Budgeteer-benders are potentially $1 cheaper!
Seriously though, I'd love to see the budget-benders work out as a paying hobby. Then when I'm less poor, I'll be able to buy one. ;)
