The lights I have with really high frequency PWM do not show their PWM on the fan or running water tests. The only way I can see the PWM on lights such as my Roche F12 is by using the cell phone camera, and even then it’s hard to see it. I have to hold the light and camera really still. The higher frequency the PWM, the finer the interference pattern on the phone.
It helps to point the camera straight at the LED, like this picture below. I had to play around with the angles before it gave me a good view of it like this. Pointing it anything other than dead on it’s really hard to see.
Also, keep in mind that this light has NO reverse polarity protection, thats another thing to consider if youre concerned about battery related issues ;)!
But realistically, can’t there be some measure of basic protection designed in simply enough? Can’t a light be made less susceptible, if not impervious, to battery damage?
An emergency light built for all batteries and fully intended for the ones you rob from remotes and the kid’s toys, seems pretty fragile if you can ruin it the first week you buy it, just because your batteries leaked, which is very common where I live.
Don’t the simple plastic battery holders offer a large degree of protection from the batteries that fit them, even though that isn’t the intention?
great review sb, I actually DO have a spare 32650 cell, bought with this light or a 1d maglite in mind, I might just have to treat myself to one of these for all of the options available though.
I have been in the habit of storing emergency lights with the batteries in them. I use scotch tape to fully cover both terminal ends, which keeps them from draining. I wonder if a similar approach would help protect against leaks. Heat shrink tubing comes to mind, but maybe something as simple as wrapping the batteries in plastic wrap would work.
I am guessing the easy solution for the reverse polarity, adding a diode in series, would rob a single D cell of too much voltage (0.6 volt drop). However, the carrier could have one built in…
I’’ve eyeballed the SD10 for quite a while, but decided it would be foolish to purchase with no battery polarity protection built in. I mean, you’re in a storm and graspin for batteries to utilize when you realize…oh oh……wrong way.
I checked with a merchant on eBay, and the Sd10 they are selling has orange peel reflector and clicky switch. I didn’t ask about emitter version but unless it’s written on the box, how can they know?
Is it possible to reprogram the driver? I haven’t found the info which one it is. I’d really like to have the single alkaline battery option, but also configurable modes.
I’m curious about this too, i want to make sure i find a supplier that has the Second Gen with the N/W emitter and the OP reflector before i sink the bucks to get this light.
Its a great light, mine has ~ <1lm output even when switched off, if not for that it could very well be my best all rounder light!
Then again, now it has moonlight mode :D!
Ha, well, if it’s going to create so much parasitic drain, it might as well use it to light up the LED a little bit. Did you by any chance ever insert the battery backwards? That was my mistake that made it never completely turn off after that.
