Leaky alkalines could potentially ruin any device.
This.
Also, keep in mind that this light has NO reverse polarity protection, thats another thing to consider if youre concerned about battery related issues ;)!
But realistically, can’t there be some measure of basic protection designed in simply enough? Can’t a light be made less susceptible, if not impervious, to battery damage?
An emergency light built for all batteries and fully intended for the ones you rob from remotes and the kid’s toys, seems pretty fragile if you can ruin it the first week you buy it, just because your batteries leaked, which is very common where I live.
Don’t the simple plastic battery holders offer a large degree of protection from the batteries that fit them, even though that isn’t the intention?
great review sb, I actually DO have a spare 32650 cell, bought with this light or a 1d maglite in mind, I might just have to treat myself to one of these for all of the options available though.
Thanks :bigsmile:
Wow, I don’t get how these fatal flaws can be left in an emergency light.
Lets hope that there will be an update soonish ;)!
I have been in the habit of storing emergency lights with the batteries in them. I use scotch tape to fully cover both terminal ends, which keeps them from draining. I wonder if a similar approach would help protect against leaks. Heat shrink tubing comes to mind, but maybe something as simple as wrapping the batteries in plastic wrap would work.
I am guessing the easy solution for the reverse polarity, adding a diode in series, would rob a single D cell of too much voltage (0.6 volt drop). However, the carrier could have one built in…
I’’ve eyeballed the SD10 for quite a while, but decided it would be foolish to purchase with no battery polarity protection built in. I mean, you’re in a storm and graspin for batteries to utilize when you realize…oh oh……wrong way.
Even SB admitted to fryin his first one.
Come on Lumintiop…Update Update Update !
Yeah, this is especially complicated by the flat top Li-Ion batteries.
This one is on my wish list for a while now - But I don't want the 'old' version.
Any idea meanwhile where I can get the 2nd generation version for sure? Preferably in NW.
I checked with a merchant on eBay, and the Sd10 they are selling has orange peel reflector and clicky switch. I didn’t ask about emitter version but unless it’s written on the box, how can they know?
Is it possible to reprogram the driver? I haven’t found the info which one it is. I’d really like to have the single alkaline battery option, but also configurable modes.
I’m curious about this too, i want to make sure i find a supplier that has the Second Gen with the N/W emitter and the OP reflector before i sink the bucks to get this light.
I have a feeling this (in neutral) might make a good candidate for a group buy. I’m sure a lot of folks would be interested.
I bought one from KD on March 2014 http://www.kaidomain.com/product/details.S022428. It has OP reflector and CW emiter.
The switch “sounds” clicky but it is electronic.
With a 32650 battery it has a parasitic consumption of about 1mA.
Its a great light, mine has ~ <1lm output even when switched off, if not for that it could very well be my best all rounder light!
Then again, now it has moonlight mode :D!
"It's not a bug, it's a feature!"
Yeah, its part clicky, part twisty design, twist to switch off, twist again to turn it on right into moonlight mode :D!
Ha, well, if it’s going to create so much parasitic drain, it might as well use it to light up the LED a little bit. Did you by any chance ever insert the battery backwards? That was my mistake that made it never completely turn off after that.
Thats an interestin observation!
No, I didnt! Perhaps they(Lumintop) did it themselves prior to shipping it out to me :D?
