This is starting to remind me of the first project light i built of this nature. i like these weaponized designs using gun parts and Pitticany rail mounts.
Making me want to buy 2 BTU Shockers and mount them to both sides of an AR-15 (maybe a third for under barrel mount) just for the comedic value that will provide.
lol thats pretty fun but cool at the same time.
i would have liked it if you used something shorter than that big o trustfire….then itll really look like a pistol…heheh
This is an amazing build. And yes, those SOIC clips can be a pain. I've gone through a couple 3M ones out of frustration when they wouldn't connect. Congrats on getting the programming working!
I reamed out the switch-boot opening to accommodate the XLR male socket, then drilled/tapped two holes from the inside and bolted the panel mount socket into place, nothing too complicated.
If I decide to go for the optional internal 18650 power I’ll probably need to mount this panel to the outside of the switchboot opening instead. Otherwise clearance inside the battery tube is going to be tight.
But for now I’ll leave it like this.
It works good as it is but there’s a few things that could be improved.
When testing with the battery cord I noticed that the current XLR plug coming from the pack is a little long and undergoes a far bit of leverage force with the heavy cord hanging off it. Also the plastic internals and especially the plastic retaining ring on this XLR socket aren’t really inspiring too much confidence in reliability. I’ve got some shorter plugs and an all metal socket on order which will hopefully make the setup more compact and sturdy.
Here’s some photos I took today of the head disassembled and showing the “pill” section in detail.
Hope they help. If you need any specific dimensions from any of this stuff let me know.
The “pill” is a single piece of aluminium but is mostly hollow. The driver cavity is massive and there is only a 2mm thick plate seperating it and the area the emitters sit on. It’s actually quite light, (comparatively hehe) especially when compared to the reflector but it’s not all bad news since the emitters actually sit on the outside of the emitter shelf. This is milled out of the solid walls of the pill and the the fins are directly below.
I also wanted to do a direct comparison between an Ultrafire C8 reflector and the BTU reflector array since that seems to be a common comparison people make.
I’ve seen people make the assumption that the BTU reflector is basically like 3 C8s side by side and extrapolate estimated throw figures based on that.
Ultimately it’s not a fair comparison because the BTU reflector cups are both wider and considerably deeper than a standard C8 reflector.
I don’t know exactly how much this affects any throw calculations or whatnot but it’s something to keep in mind
BTU reflector size is 48mm deep x 43mm wide
C8 Reflector size is 31.5mm deep x 38mm wide
The C8 reflector feels like it’s made of paper after handling this beast!
So… finally, finally after 39 days of not very patient waiting I have myself some MT-G2 emitters on noctigons!
These things are huge and gorgeous. I can’t wait to light them up.
I was a bit surprised to see that this one emitter is not particularly well soldered to the pcb.
It’s not sitting completely flush on the solder pads and slightly cocked up at one end. I wasn’t expecting that from Intl-outdoor but I guess it can happen, shouldn’t be too hard to reflow in any case.
As big as they are, the fit into the BTU reflector is actually a bit looser than I was expecting. Maybe I need to make some centering rings for them.
Just a quick assembly to see how things are looking.
MMmmm triple MT-G2 shocker, time to get cracking on the electricals to feed these bad boys! :bigsmile:
In the same order I also got the infamous 9A IOS buck driver, I won’t be using it to drive the emitters in this light but I plan to do some MT-G2 testing of it to see what’s what. Hopefully with some direct heatsinking it can still make a suitable option for driving a single mt-g2 at over 5A reliably.
My particular sample came with 3x R200 sense resistors on the top of the board and 6x (double stacked) on the bottom for a total of 9. I’m having trouble finding the thread where the sense resistor formula for this driver was discussed but I assume this combination should indeed deliver 9A output to an XML. I’ll see when I start testing anyway.
So I tried fixing the reflow on that one wonky emitter but noticed that once the solder had melted I couldn’t get it to sit flat either. :~
It sorta rocked back and forth in a weird way like a see saw so I removed the emitter completely and found a chip of what looks like dried fujik stuck to the flux underneath it.
Very strange, must have gotten in there by accident on the assembly line.
I cleaned off the fujik chip and tried reflowing it once more. This time it sat down nice and snug with a hopefully solid thermal path to the pcb.
