See my thread here on a 2x-AA sized P60 I built up for a friend, using a 501c host. I've got the parts list including the driver I used to assemble the drop-in. It's worked out really well, is a decent brightness, and low modes make for great runtime...
I’d opt for the Klarus too. Low voltage P60 drop-ins aren’t very efficient. Output and runtimes won’t come close to the Klarus. And the Klarus is less expensive.
Hello everyone, I’m Tango. I’m preparing to start rebuilding a SureFire C2 as a form of physical therapy and happened across the Solarforce’s website. My query for those who might be better versed with Solarforce bezels is this, will the Solarforce T2 head with LED properly mount and thread on the SureFire C2 host body? Also, I see that they claim their S8 tail switch will work on the 6P, 9P & C2, is this correct? Thanks in advance for any assistance that the forum can offer.
Don’t have either, let alone both, so can’t quite say.
But even if by chance thread pitch is identical, I’d be careful because some are triangular-cut, square-cut, even trapezoidal-cut. They might “fit but be snug”, in which case be really careful snugging them up.
Thanks for the advise, I was not aware of this. I’m already found a few things that I’ll be using for this rebuild already but I’m in no hurry, just planning and taking my time on it.
Yeah, even with the same mfr, standards change. Eg, ignoring anodisation, some battery tubes are reversible (vs flipping the clip) and others aren’t. Some have different threads in front vs in back. Etc.
I’ve only got L2Ms, and frankly haven’t even tried flipping the tube.
Mixing Solarforce vs Surefire… dunno, but wouldn’t place any bets.
Yes, pretty much all the SureFire line are great lights though they are not all that cheap but you get what you pay for. LOL I’ve been a diehard SureFire carrier ever since the early 90’s and it wasn’t till recently that I started to look into rebuilding a C2. I could easily just through a drop-in in the light and be done but I’m looking to tweak the tail switch, upgrade the lens, give it a space-age look as well as boost its output and maximize its battery life and add a strike bezel.
any Solarforce host with a c123 extender does 2aa, just need to put some o-rings on the batteries to stop them rattling around inside, I’ve got an l2p with the extender and a low voltage neutral xp-g2 with 2aa nimh that works well for occasional use by the back door.
It might be worth checking out LumensFactory. Lumens Factory
I have been happy with their parts and they make some of the parts you mentioned, crenellated bezel, lens, switches, etc. Their clips look nice too. Hope that helps.
I have a C2 and L2M. The head and tail caps are interchangeable.
The solarforce parts have more variability in the threads and occasionally don’t thread smoothly on the Surefire bodies.
The biggest variability is in the head where the light engine goes. The Surefire is a little smaller, often requiring the outer large spring to need removal.
The Solarforce head often requires this spring.
I’ve checked out Lumen Factory and there are a few parts that I intend to acquire for this project light. I’m not really interested in clips on the light being that I’ve never used that feature on any on my SureFire lights before. Thank you for the recommendation of Lumen Factory though, they do seem to be one of the top maker of parts.
Thank you for answering that side of the query in reference to the L2 to C2 switch, from their wording I thought it might but just needed to check as they also mentioned L2 which as it turns out is a model of SureFire light as well. LOL
Does anyone have knowledge about the T1 or T2 head fitting the SureFire C2 body?
