I ordered a Ganzo G704 with the green handle yesterday. I will compare it with my Ganzo G704 (I have the last two editions of it).
Yeah, I really dig the green handle on those. I will likely order 3 of them, one for me and each of the older boys.
Tons of Marsfire lights released today but all seem overpriced and only a few look to be unusual enough to warrant a look at. A few other brands are out as well today...
PALIGHT M900 1*Cree XM-L2 T6 6-Mode 900LM LED Flashlight for $34.42 or $32.69 after BLF discount
black / 1*18650 / 1*26650 / US plug
MARSFIRE Z8 1*Cree XM-L T6 5-Mode 800LM Zoom LED Flashlight for $37.00 or $35.15 after BLF discount
black / 1*26650 / US plug
Sofirn MS5 3*Cree XM-L U2 3-Mode 2500LM Diving LED Flashlight for $150.83 or $143.28 after BLF discount
grey / 4*18650
Quite a bit pricey but it looks like a pretty solid diving light that could take a lot of abuse.
Flashlights | |
FLASHLIGHT MODES | Hi > Mid > Lo |
LENS TYPE | Glass Lens |
MODE COUNT | 3 |
MODE MEMORY | No |
REFLECTOR TYPE | Aluminum Smooth/SMO |
SWITCH PLACEMENT | Side |
SWITCH TYPE | Twisty |
TAIL STAND | No |
TAIL-CAP CURRENT | 2800 mA |
- Reflector diameter: 2.7cm
- Head diameter: 6.2cm
- Tube diameter: 5.7cm
- Tail diameter: 6.0cm
- Beam range: 300 meters
- Complied with IPX-8 waterproof standard, 30 meters submersible
Warm White LED Doctor / Nurse Medical Emergency EMT Pen Light for $2.20 or just $2.09
- Pupil gauge: 2-9mm
- With 5cm ruler on the penlight
Light Sources | |
LIGHT SOURCE COLOR | Warm White |
Power & Batteries | |
BATTERIES INCLUDED | No |
BATTERY FORM FACTOR | AAA |
REQUIRED BATTERY COUNT | 2 |
This two flashlights are interesting, because you can use in the first one 16340 or 2x AA. The second is a bikelight or usual flashlight (1-4x 18650).
MARSFIRE 616 1*Cree XP-G2 R5 3-Mode (hi, low, strobe) 400LM LED Flashlight black / 1*CR123A / 1*16340 / 2*AA. In the Marsfire Alibabashop is also written: 1x 18500 (not 18650). Fasttech wrote working voltage 3,6-4,2V. I ask if they can test it with 2x AA and correct the description. Price $21,11 (with BLF $20,05). My link - non aff-link
MarsFire 663 1*Cree XM-L2 T6 5-Mode 900LM Cool White LED Bike Light / Headlamp / Flashlight grey / 1*, 2*, 4*18650. It's possible to use it with 1-2* 18650 as a flashlight (maybe you should remove the mount if you ws it often as a flashlight). If it should be used as a bike light you use the 4x 18650 batterypack US plug.
Price $73,72 (with BLF $70,03). My link - non aff-link
New intresting stuff from Fasttech… Im tempted hence I don´t own any SRK-lookalikes.
UltraFire L-6XL2 6*Cree SRK-clone
UltraFire LW-12L2 12*Cree XM-L2 T6
Seems pretty potential. What do u guys think?
Sorry for being a noob and not knowing how to link pics straight on the thread.
not affiliated.
Lots of new knives and lights today
http://www.fasttech.com/category/1/new-products/LTI9MTEtOS0yMDEz/
UltraFire S4-L2 4*Cree XM-L2 T6 4-Mode 3200LM LED Flashlight for $48.29 or $45.87
Flashlights | |
FLASHLIGHT MODES | Hi > Mid > Lo > Strobe |
MODE COUNT | 4 |
MODE MEMORY | No |
SWITCH TYPE | Forward Clicky |
TAIL STAND | Yes |
Dimensionsus | metric | |
DEPTH | 65 mm |
HEIGHT | 163 mm |
WIDTH | 105 mm |
PRODUCT WEIGHT | 585 g |
I ordered one of the newly posted knives, a little slip joint at $3.26 it seemed rude not to. :bigsmile:
I wonder how easy it is to remove those springs.
I wonder about the quality of the Rimei brand. Prices are so incredibly cheap! Anyone here familiar with them?
That Cold Steel knife in the video looks fantastic. I hope FT will add it soon. Time to submit a product request.
I know it’s not a flashlight or normal EDC item but I know there are many other vapers on BLF besides me that might be interested in this
Ok, am I crazy for wanting this bad boy? Too much money for a mod? It’s actually a very good price as this mod sells elsewhere for $200 or more. I haven’t read a bad review on it yet and I’m waiting for the black and stainless version to come out as I think that one is even sharper than the all SS version. The first time I saw the two tone version it blew my nips off!
Innokin iTaste 134 for $107.26
The 134 is a VW only mod and is adjusted by twisting the control ring in the center of the mod. Looks just like the Gatling Gun light.
Details:
Tips: The iTaste 134 is a microprocessor-controlled VW mod that allows you easily adjust the wattage with a rotational wheel. The solid stainless steel body gives it a fairly hefty weight. With 510/eGo threading, and a removable beauty ring, this mod will compatible virtually any clearomizer, cartomizer or tank.
Power On/Off: press the firing button quickly 3 times
Adjusted with the rotational wheel to 6.5W, 7W, 8W, 9W, 10W, 11W, 12W, and 12.5W
Battery level indicator: (green = fully power; yellow = medium power; red = low power)
10-Seconds cutoff
Short circuit protection
Reverse battery protection circuit
Low voltage warning
LED light blinking mode
Removable beauty ring
510/eGo threading connector
Can be powerd by 18650 battery ( battery sold separately)
Comes with a iClear30 dual coil clearomizer(with rotatable drip tip)
That is a LOOKER!!
Very much like the gattling-light.
If I was a smoker, I would get this for sure…
i just recieved a black innokin itaste 134 “gatlin”. nice piece of kit
I would really like one, but can not bring myself to getting such an expensive mod that probably wont put out the watts that I am used to.
I´ve tried many mods but I just love my Provari Mini. A good RBA on top and dripping is a sheer pleasure!
I ordered one which might be a Rimei, but I’m not totally sure. It was this one:
http://www.fasttech.com/product/1069504
… which seems very very similar to a Rimei product they have:
http://www.fasttech.com/products/1901/10006652/1196202-rimei-5973-stainless-steel-foldable-tactical
It looks nice, but the quality of mine isn’t very good. Its liner lock is thin and relatively weak, and the blade won’t stay completely closed even if I simply turn it upside-down. I can open it with the gentle-est flick of my wrist, but at least it stays open. There is a bit of a painting/anodizing error at the tip of the blade, and the blade is labelled “CRKT” (hah). But what I got may be only a cheap copy, despite having a slightly higher price than the Rimei one. In any case, it’s nowhere near as nice as my SRM or Enlan or even Tekut knives.
So, it gets used only to open mail. For that, it’s not bad.
A new knives brand is available. I have never heard something about the company and the knives aren't available in many places. It called Omuda. All should be made of 440C stainless steel and come in colored box with a window - not only in a white box.
This three are the only one, which looks a little bit more interesting for me.
Omuda 3915 70mm blade, a liner lock and a clip. $7,66 My link - non aff-link
Omuda 3913 75mm blade,a mono lock and a clip. $7,58 My link - non aff-link
More intersting for me is the Omuda 3912 with a 85mm tanto blade and a clip. $9,05. My link - non aff-link
A fixed blade with the name CT343. It looks like the Colt CT343 but without the brand and the horse on the handle. Maybe it is photoshopped like the Ganzo knives a few days ago.
Blade length: 95mm, blade steel: 8Cr13MoV. Open length 199 mm, product weight 199 g, thickness 3.8 mm. $10,76. The Colt CT343 is sold on aliexpress or ebay for $18-20. My link - non aff-link
I quite fancy one of these boot knives . It’s probably soft 5-7Cr13MoV but reminds me a little of the Gerber Guardian. Do I really need another letter opener though? :weary:
This Soshine power bank seems interesting too:
http://www.fasttech.com/products/1/10006661/1521600-authentic-soshine-e1-1-1-lcd-10100mah
A little expensive but has a display like the one in the SC-S7, two USB ports and a nice silver power button.
