How about setting up deal for the 2600mAh Samsung for the more budget-oriented users here?
Iâm thinking 4pack deal would be a nice compromise (as they also need volume to cover shipping). Since itâs already at $4/piece for 3+, thatâs $16 for 4, if you can get it down maybe down to $13 or close Iâm definitely in.
3 x Registered, but also 2 x unregistered. Both methods arrived safely and took about same amount of time.
But my suggestion is to take two pairs at a time, which is over the free registered shipping limit ($25) but just under the EU VAT limit (22âŹ) [Based on Finnish customs currency conversion rates for November 2013, your own country might use different currency conversion rates..]
Standard BLF discount code will work on most flashlight related items, prices are already bottomed, I doubt they will be able to offer significantly bigger discount than what it is already with BLF couponâŚ
Anyway, no updates for any of my orders from october 21 :~
Please don't try to hide your affiliate links to short URLs.. Luckily goo.gl URLs and click analytics are public and can be accessed by anyone (who knows how to): See the analytics and full URL here.
Well right down that list the UR18650ZTâs are advertised and those are 4.3v cells. I think the question is wether or not these are protected versions of those cells.
But if they are 4.35, but have protection to 4.2, then a 4.35 charger would still not get them to 4.35⌠is this correct? I know Fasttech has two versions both with same number, but one says 4.2 and one says 4.3. Unless the PCB is different on the 4.3 version, I donât understand how they can be different. And donât know how one would tell them apart if you had both versions.
Donât know what the cutoff is on the PCB. Most chargers cutoff at 4.2 unless you are going to use a hobby charger so I wouldnât buy them. I bought some from FT before I realized they needed 4.35 to get to the full capacity of 2800mah. Donât know what the PCB cutoff is because my chargers cutoff at 4.2. Have a hobby charger but itâs a heck if a lot easier to pop them in a regular charger, not worth the hassle, just buy different batteries.
I happen to have some of them, I tried different batteries in some of my lights and found they are longer than my 3400 Panasonics, so I will be sticking with the Panasonics.
