Deal alerts for Banggood.com - BTU Shocker, SolarStorm, Olight, XinTD...
Xintd from BG uses a traditional nanjg 105c. Based on the description, its the one where you can hide strobe and sos.
Qlite is exclusive to intl-outdoor.
The nice features of the Qlite over a regular nanjg 105C are:
-No PWM whine.
-No visible PWM
-Better mode spacing (IMO)
-The ability to set it up with moonlight
-Low battery voltage cut off (makes it much safer to use unprotected cells)
IMO, Qlites are superior to the regular nanjg105C firmware. But the price on that X3 from BG. Its nice.. :)
Maybe _the_ can negotiate a special coupon for it? ^^
Thanks a lot! Appreciate it.
+1 Hint hint to _the_ ;)
Oh, and the Qlite also uses 8x380mA regulators= 3Amps on high
Regular nanjg 105C normally use 8x 350mA regulators= 2,8A (it could be using 380mA)
Qlite also runs from low to high
not high to low
1st Star : 2% - 25% 100% (Default)
2nd Star : 5% - 30% - 100% - Strobe (10Hz) - Beacon (cycle: 2Hz blink, 4seconds light off)
3rd Star : 15% - 100%
4th Star : 20mA - 2% -25% -100%
I think these other lights start on high ........which I don't like
What ?
No finders fee ? :wink:
XinTD X3 is already very affordable ($31.72 for U2-1A with coupon blf) so they won't go any lower. [Tried hard. Didn't help. Sorry!]
Edit: Tried once more, might help, please wait..
Edit2: Helped a little. See below. :)
XINTD X3 are all Tint options XML2?
other lights explicitly say XML2 T6 4C.. while this one says XML T6 4C...
just wondering
Do you think this will make much of a difference in final output?
XinTD X3 U2-1A for $31.03 (with coupon bgf141)
ChibiM: It says XM-L2 in every place on that page, and Neal just confirmed me that all tints are XM-L2.
sb: You won't notice it. :)
Just look at the XinTD pictures, there’re Simon Mao’s mark. Should be not bad, Convoy-XinTD X3 or XinTD-Convoy X3 :open_mouth:
Side by side, barely, but without both to compare with, not at all. :slight_smile:
Hmm, my only reservation about buying the Xintd X3 is that the reviews mention that it doesn’t work with protected Li-Ions because of the longer length of the cells. I strongly prefer protected cells, so that’s kind of a downside.
3,04A-2,80A=0,24A extra.
In real life the difference is more like 0,15A extra based on what I have seen. (due to 350mA 7135s usually overperform, and the 380mA sometimes underperform. Qlite might also have a tad of PWM on high)
0,15A difference is close to nothing.. Its about 5% more current. Which probably is no more than 4% more light on high..
Thanks for the coupon code _the_.. Tempting, tempting... Im not supposed to buy this light...
Couple of new interesting light on Banggood (soon with discount :bigsmile: ):
Fenix HL10 (Super mini 1xAAA head light)
Fenix HP11
Fenix HP25
ROCHE M170 3xCREE XML2
I have ordered the extendable baton, it is irresistible price.
I am not happy with SK68 clones I have received from BG. May be this time they will do good.
Regarding those X3 tints, can anyone give me a short description which tint is what?!
T4-7A
T5-5B
T6-3B
T6-4C
U2-1A
:smiley:
I found this pretty informative.
Agreed, there’s another “ANSI-chart” here, a bit easier to read the text. File:Ansi-white.jpg - Flashlight Wiki
EDIT: Hotlink removed, thanks the
That's what I always use. However, flashlightwiki doesn't like hotlinking, so here's a link to the page: http://flashlightwiki.com/File:Ansi-white.jpg
For a description of those tints, basically, this is what I have found:
  • 7A = very warm
  • 5B = neutral, tending towards yellow
  • 3B = neutral, tending towards cool
  • 4C = neutral, tending towards red (this one is described as very pleasant by many)
  • 3C = standard “neutral” tint (not available for the Xintd for some reason, but probably the most common tint described as “neutral”)
  • 1A = standard “cool” tint (by far the most common tint on most flashlights)
This post was also helpful: What LED tint do you prefer?
