Yes sorry folks , the grip ring is very well color matched , the clicky on the L2T is standard forward switch .
A normal L2 is reverse clicky .. Im not sure if you can buy the L2T with anything else but the forward clicky , you may need to mod it if you want reverse .
Though using a forward clicky is no real issue , except changing modes takes a little more work .
Can you check if the switch circuit in the tail is the same as the l2? SF will sell you one for $2, I found out because I burned one by putting the battery backwards.
Also, is the coating HA-2/3? Ie, is it scratchproof?
I have been waiting for someone to get their hands on one of these. I think it looks real nice. I have to find a good holster, it doesn’t look like it will fit in the open holsters I use.
Anodizing ? Feels more like it were parkarised , anyhow , Solarforce description .
L2T
The L2 Series has been becoming more and more popular in the public market since it first production. In view of this, Solarforce now provides users with our newest model of the L2 Series �V L2T. In addition to the remarkable features of flexibility and wide-application of the L2 Series, the design of L2T is a combination of style and practical nature. The L2T bodies are mainly constructed of precisely CNC-ed aluminum alloy and consisted of head, battery tube and tail-cap switch as its major parts. Users may install various high-efficiency bulb modules and / or accessories to the L2T depending on their needs.
Specifications and Features:
-Consisted of head assembly, battery tube and tail-cap switch (bulb modules are not included), which are replaceable and compatible with Solarforce accessories designed for the L-Series
-Body constructed mainly of T6061 T6 aluminum alloy
-Compatible with various Solarforce LED and xenon bulb modules
-Forward click tail-cap switch
-Colour: black
-Uses two CR123A or 16340, or one 18650 battery by default
-Standard tail-cap click switch
-Water-proof design
-Size (length x head diameter x battery tube diameter): 136 x 32 x 25.4mm
-Weight: 87g (excluding drop-in modules and batteries)
I love the look of that new head more than any of the others as well as that awesome matte finish it has! If the body was knurled like the others but with that matte finish it would be so pimp. I think it would make me consider getting my first SolarForce light.
My HA stuff flakes....even for Dereelight quality, but its really a very minor flake, usually its at the edges.
The guys at CPF says that only the top few lights have HA that are good enough not to flake, their Fenix etc all flake to a certain degree with hard usage.
But seriously, this type II surface really has a confidence inspiring surface, more so than my L2P / L2X.
