Great review; thank you.
Bought one, too...impressive throw for a 2xAA. Very well built as well. The Nitecore MT21A and the Klarus P2A are the top of the heap in the buget 2xAA category.
Thanks again for a very informative and enjoyable review.
Received!
If I have to figure out one rant, reflector is a bit foggy like in Thrunite´s products.
Otherwise 5/5 easily if you like this format!
Now that´s a ringy beam : /
…once he posts some outdoor shots the effect will disappear. The beam on mine is not ringy at all. As was said, if you like the format, this light is an extraordinary bargain.
First of all; Thanks for the informative and in-depth Review of this Terrific light. Mine arrived late on Saturday; I got a Great Deal from Battery Junction(less than 25 Bucks), and I am Very Pleased. I was just about to buy a MT1A(and I Still might) when I ran across the BJ Deal, and I couldn’t be happier. I Love the UI, and, like the, my default is Turbo+Low. The Strobe is different from any of my other lights; I don’t know technically if it’s Better or Worse, but it’s definitely Different. Previously, my only 2AA lights were the Rayovac Indestructibles, which I also like, but obviously for Different reasons. I kept one Indestructible on the nightstand(this MT21A now is my go-to nightstand light) and one in my Truck because they’re too bulky/heavy for EDC. This MT21A could be a Great EDC for me(I’m 6’6”–275lb) as well.
Thanks for sharing this review. I just picked up one of these for only twenty bucks (used, but in fantastic condition) on CPF MarketPlace. Very nice light for the money. Love it! This makes NiteCore #3 :) (EA4 and a P25 were the first two really nice).
Edit: I’ve tried sharing a picture (through Photobucket), but it doesn’t seem to be showing, here. Not sure what I’m doing wrong.
Thanks for the heads up the I’ve been looking at this light for a while & it seems a great value at $30 much less $25, but yikes some of the reviews on that retailer:
Anyone here bought from them before?
edit- i dont want to link it in case it seems like im affiliated or something, but it’s $1 more at a much higher rated seller, with a keychain light, not that that’s worth $1.
Nice review, thanks
I am wondering how much time it can run in mode high.
Hava any person tested it?
Great write up, I (my dad) have a MT2A. Very similar in most aspects, must say that it is a good simple UI but I think that hidden blinky and L-M-H (like phantom23 said) would make it a tad better. That is relly my only gripe with the light.
I know this is an old, old thread, (and a great review by the way!), but I was wondering if anyone who still owns one of these has had trouble with parasitic drain?
I pulled mine out a few weeks ago and installed fresh Energizer Ultimate Lithium AA’s, (expiration date of 2023), and used it for a job under the kitchen sink for about 5 minutes. I turned it off and set it on a table. I went to use it again yesterday and noticed the beam was very weak. I checked the freshly installed cells with a multi meter and they were over halfway depleted.
Anyone notice this with yours? I know you can lock out the switch by loosening the tail cap but I hate lights with parasitic drains.
I’m not sure about the MT22A but I have two of the MT2As (similar light) that I keep in the cars with eneloops. I charge the batteries every 6 months and they’re never dead when checked.
Mine’s the MT21a as reviewed here. Maybe mine’s defective but other than the weird battery depletion it works fine.
My mistake, MT21a.
I suppose with a jumper wire and couple of extra hands you could put a DVOM in series with the tail cap and measure parasitic draw.
I’ve had an MT21a for about a year now and keep it around as a mostly unused emergency light. I put energizer nimh batteries in it and charge them once a month to keep them topped off. I don’t lock out the tailcap and they always have a good charge left in them at the end of the month, so if there is parasitic drain its minimal.
Thanks Itinifni but I don’t have the technical knowledge to do that.
Thanks jch10400 for the feedback.
Like the stated in his review, even on turbo this is not a barn burner or anything even remotely close. It was a nice light back in 2014 but oh, has light technology advanced since then.
It’s still a nice light but parasitic drain, at least in my example, makes it a not so nice light.
I swapped the LEDs in both of my MT2As and XP-G2 5A1 in one of them and XM-L2 U5 7A3 in the other. Within the limits of a 2AA light I think they’re great!
I had mine since it was available.
I’ve had put it in the car for emergencies (and stuff). Been there for a couple of months on average. Two times I had to use it and the Eneloop XX batteries dies in less than 15 minutes on high. Back then I just thought that the batteries are losing charge after time, but now when you mentioned it, maybe there IS parasitic drain.
I retired mine and I’m using some SolarForces with 18650 in the car now. Never had a problem like this since.
