MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
I’ve never fully understood exactly what makes a CC/CV charge cycle so good in the first place, so I wasn’t sure.
Is it simply that the CC phase protects the cell from overcurrent and CV kicks in once we reach the maximum voltage for the cell? Would a pure CV charger result in anything undesirable other than a slow charge?
All CV would give a faster charge - too fast. Say you start with a resting voltage of 3.6v, if you apply the full charge voltage across it at that point, the cell will accept many many amps. The CC phase is required to limit the current until the difference between the actual cell voltage and desired finish voltage are closer together. Less spread between actual & desired self-limits the current to a safe range, so holding a constant voltage just a tad over the desired full charge voltage until it finishes is fine.
When I manually charge the 4.3v cells starting from 4.2v as they come off the hobby charger, it's all CV as that difference between 4.2 and 4.3 is small enough that limiting the current isn't needed to stay in a 'safe' range. It limits the current on its own.
Duh, brain fart. First I write that CC clamps the current to protect the cell from overcurrent, then I suggest that CV only would be slow…. clearly a lack of thought. Thanks!
Are you trying to suggest we’re hi-brow here ?
Last thing we need is to become a clone of that other place :wink:
Will have to try one of those next :) Just wanted you to know that this has been the best one so far (I've tried a few others). I have used Yiboyuan phone battery chargers for years with my Droid X and now HTC Rezound, no problems with them whatsoever.
FYI:
More small flashlight holsters in stock, along with the butterfly style XM-L emitter spacers.
Here we talk freely and openly, which inspires suggestions and innovation. Like what Richard is doing with the 4.35V chargers and the feedback.
You don’t have to be on here long at all to have people run amok in your thread, but they most always come back around. :wink:
Richard, any sign of the Convoy C8’s ? No hurry, just wondering.
Indeed, should see them something this next week.
About the charger, no it isn't the most eloquent solution, but it works great and has been reliable. Besides, this is budget light forum, right? I have been testing it all week long to make sure that it was good to go before announcing it here. None of the other solutions I've tried or looked at up until this were going to be cheap enough to be worth it, to me at least.
Has anybody tried a MTG2 in the Convoy C8's OP reflector?
I can see if it’ll slip over the one in my copper light engine, see how the beam acts.
Not yet, I guess it might fit with the copper pill? The factory aluminum pill only fits 16mm MCPCBs.
Not as easy as that, emitter hole will have to be opened up. I will be doing this in the next couple of weeks, have a project going on to compare apples to apples in a Cree Trifecta using Convoy C8’s as the hosts.
Yeah, and...? :bigsmile:
Anyone tried an MTG2 in the Convoy M1 host?
Hey! Been super busy with all the orders and holiday events these past few days, but here are some updates (are either currently up on the site, or will be there in a few hours):
New:
  • Bare XM-L2 1A LEDs
  • Bare XM-L2 1D LEDs
  • Bare XP-G2 R5 3C LEDs
  • Bare XP-G2 R4 5A1 LEDs (for you warm tint afficionados!)
  • 14mm XM-L2 3C (aluminum star)
  • XM-L2 T3 7A3 on 16mm and 20mm Noctigon
  • P60 Bare Dropins - Orange Peel & Smooth Reflectors
  • 20, 24, & 26 AWG Silicone Wire
  • Arctic Alumina Thermal Compound (14g)
  • Convoy S3-like host (identical except it doesn't say "Convoy")
Restock:
  • 20mm & 42mm AR Lens
  • qlite drivers
  • Plastic 3M Emitter Insulating Gaskets - XP and XM
  • XP-E2 R4 1C on 16mm Noctigon
  • XM-L2 T6 3C on 16mm & 20mm Noctigon
  • XM-L2 T4 5B1 on 16mm & 20mm Noctigon
Probably some other stuff I'm forgetting right now, but that's most of it!
Awesome job Richard!
Packaging is nice and those little boxes make great storage. :bigsmile:
You'll notice that I am now offering an assembly service for flashlight hosts and P60 dropins. Look soon for de-domed LEDs and a few more things!
Pretty decent price for assembly service.
For the S2 and S3’s you have “Just check the box and also add your choice of 17mm driver and 20mm LED to your shopping cart.”
That’s great news. I just placed an order for a custom P60 Drop-in.
Its going to have:
-XM-L2 T4 7A3 80+ CRI
QLITE REV.A 7135*8 3.04A Driver (5mA 2% - 25% - 100%)
-Orange Peel reflector
I am going to use the firefly mode as sort of locator glow and 2% as my night light.
can’t wait! :slight_smile:
some website issues...
when clicking on the top tab - "Flashlight Hosts" your flashlight hosts are hidden. Some people new to your site might not even see that you have light hosts.
You might consider moving your flashlight hosts under "Flashlights" tab.
and move empty P60 drop-ins under "Components".
Maybe on your Silicone Wire page add an Ampacity Chart like (wiki), since this is one of the more important specs when choosing AWG. ppl should know... what is the recommended max current for a certain wire size.
After-all the site is quickly becoming a modder's haven.
as always great work Richard.
