My collection in my display case. (Around the house and in my pockets are several more lights spreaded)
Not as nice as some of you, and as of now most of them are cheap, but since the last couple of months I’m more focused on better quality and brands.
Picture is not so great as I just took a quick snap shot with my cellphone.
It’s not really a matter of not liking them, it’s a matter of getting some lights that will power on when needed (and just another reason to keep buying :P)
And modding is a whole next level. The goldenbrown one second from the right on the top was disassembled and reassembled by me, now the tailcap isn’t working anymore, and I’m almost positive I put everything back in as I took it out. Light turns on as soon as I twist the tailcap on and won’t turn off anymore until I twist it back
Ah well, at least it’s one that I already didn’t use that often anymore.
I only have Fenix E05 and Olight S10 L2 in my collection. I also acquired a couple of Energizer Lithium (AAA) and Nitecore RCR123A with Nitecore I2. Just Ordered a Convoy C8 and a couple of Sanyo UR18650FM. I don’t looking to add more lights now maybe after a few months.
Flashlight collection? off the top of my head without looking:
1xAAA lights:
Fenix LD01
Liteflux LF2XT natural anodizing
Liteflux LF2XT black anodizing with emitter upgrade to XPG R5
Tank 007 TK703
1xAA lights:
Eagletac D25a titanium XPG2
Jetbeam BK135a
Jetbeam PA01
Sipik SK58 (modded to XML2 neutral, 4 amp, electronic switch)
Sipik 58 (modded to triple Nichia 219 @ 3 amps)
multiple Sipik 68s and clones
XTar WK41
Sunwayman V10a XPG
A couple LED Lensers (I forget the exact names)
Zebralight SC52
Zebralight SC52w
Spark SL5 neutral XML
Zebralight SC80 XPG
Thrunite Neutron 1A
4-Sevens mini AA XPG
4-Sevens mini AA Titanium XPG
1xCR123 lights:
Eagletac D25c aluminum 2012 neutral XML
Eagletac D25c aluminum 2013 neutral XML2
Eagletac D25c Titanium 2012 upgraded to 5000k neutral XML2
Jetbeam RRT01 (modded to XML2 neutral)
Jetbeam TCR01 (titanium)
Olight S10 (modded to XML2 neutral)
Olight S10 Titanium
XTar WK42 (modded to 3 amp XML2 neutral)
Sunwayman V10r XML
Sunwayman V11r XML
Lenslight Mini XPG neutral
Spark SF3 neutral XML2
18650 size lights:
Convoy M1 (modded to 4.5 amp MTG2)
Roche F12 (emitter swapped to XML2 neutral and lens swapped)
Roche F12 (modded to triple XPG2 neutral at 4.5 amps; battery tube cut down to 1x18350)
Zebralight SC600 (early model)
DQG mini 18650 (first version)
Shiningbeam S-mini (neutral XPG)
Sunwayman C20C (emitter swapped to XML2, but will shortly attempt to mod to MTG2 @ 3 amps)
Other:
Probably 15+ other cheap budget LED lights of various sizes, some modded, some not. Many of them zoom lights.
Several old Inova lights, some with 5mm LEDs
Lots of cheap keychain LED lights with 5mm LEDs
My earliest LED light: a small plastic keychain light with a titanium sleeve. Powered by 3-button cells. Light source is a 10mm red LED. Purchased at least 22 years ago.
Various old incandescent lights: small maglites, 3 battery powered fluorescent lights, a couple Underwater Kinetics dive lights.
_
My current EDC is my modded XTar WK2, now equipped with 3.04 Nangj 105c with DrJones Lumodrv, a Radioshack micro-momentary switch, and a 5000k XML2 neutral on Noctigon.
You are not allowed to make posts like this promoting your business. You are not posting here as a regular user, you are posting here as part of your job. READ THE RULES you agreed to when you signed up--> http://budgetlightforum.com/forum/misc/commercial
