Yes it will work! You definitely want an orange peel reflector to help smooth out the beam a bit, and I do think that the less focused reflectors are best for the color XM-L. This is because the four dies are all seen as slightly off-center by the reflector, if that makes sense. It will still work well with the larger C8 reflector but the projected image becomes less round. If you don't care about throw, the S3 may be even better since it barely focuses at all with that tiny reflector.
Added the Small Sun ZY-T08 along with a few "mod" options. I've built a few of these for myself and friends and they are one of my favorite hosts!
Re-stocked some of the springs and I have some 17mm and 20mm forward clicky switches that will be on the site soon.
Next up? Re-organizing some of the site (categories, etc.), new battery shipment should be in next week (more Prot. Pana. 3400s, unprotected Pana. 3400 button top, unprotected Pana. PF button top, etc.), also some DIY triple kits and pre-built triple lights.
Sorry if it seems like updates are slower than usual, I've been too busy having fun (and shipping orders) to spend as much time on the site as I usually do! Don't worry, I'm not getting burned out; in fact, I think I'm just getting started!
No go on the forward clicky (at least not without a lot of work). The stock switch in this light is very small, it took a lot of filing and grinding to get even the smaller Omten reverse clicky to work.
RMM, is the T08 just a host or is it the complete light and you simply replace stuff? I ask because it’s called a host but categorized as a flashlight.
Got some nice goodies in a little box in the mail today! Thanks Richard, neat to see that tiny little box with the mailing label on it. Came through just fine.
On the Small Sun you’re talking about above, you say it has a Qlite at 5A, then go on to say it’s running the XM-L2 from 2 cells but can run one. How are you doing that on a Qlite?
Edit: nevermind, I looked the light up and see how it’s made. Yuck! lol Not for everyone is it?
It is the complete flashlight but I admit that I've never been able to leave it stock.
The cells in this light are in parallel so you can run one or two cells but if you want to hold 5A with an XM-L2 for any reasonable amount of time you really need two cells.
I have converted a few to serial configuration for an MT-G2 but the stock light and the mods I'm offering are parallel.
Sorry for the confusion, been doing a lot of cell phone edits on the run.
I'll get some reflowed in the next couple of days and let you know (unless I destroy them all in the process! )
I just changed the way that the P60 dropins are listed, as well as a few other tweaks. I will continue to work on simplifying the site and implementing some of the excellent suggestions I have received from all of you!
Damn, you answer fast. Thanks!
Some people looking for shrinkwrap due to the keeppower issue. Just remembered you started carrying it. Now I can mention they don’t have to wait 3 months for FT.
